Question about Asrock P4VM8 Motherboard
Vga i have onboard vga on the asrock p4vmb motherboard but cant get no output to my moniter
  • Mark Grummell May 11, 2010
    Did you buy a used board? if so, it is possable that the bios is trying to output to an add on monitor. First, try to reset the CMOS, (usually by moving a jumper, trying to power on the system, powering it off and moving the jumper back) or you could try using a card to see if that is the problem, if so, it is just a manner of changing the bios settings using the card to be able to get in. but i cannot help beyond that.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try reseating your memory one stick at a time in each slot one at a time and see if you can get video back.
  • 101 Answers
Try to connect PC speaker and listen his sounds for diagnostics
  1. one short - system is good
  2. one long, three short - poor video card
  3. three ore more long - poor memory RAM module.
Posted on Mar 07, 2009
No VGA output
Hello the drivers site is here:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=G41M-VS3
The manual:
http://www.asrock.com/mb/overview.asp?cat=Manual&Model=G41M-VS3
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Nov 28, 2012 | Asrock G41MVS3 Motherboard
Hi i need to asrock p4vmb sond card .tkuuuuuuuuuuuuuu
Hi, you can download the xp driver here:
http://www.asrock.com/mb/download.asp?Model=P4VM8&o=XP
Please unzip the file before installation.
Sep 12, 2011 | Asrock P4VM8 Motherboard
HI this is pradeep iam using ASROCK motherboard processer AMD Anthlon(TM)XP2600+ for this motherboard which graphic card can i use my problem is i brought dell 24inch moniter ST2420L but graphic...
Asrock K7VM3 mother board with AMD Athlon 2600+ processor.
The Motherboard is having a AGP slot which says to use AGP with 4X and 1.5 V
Can someone suggest the market products available
when I contact the technical team of Asrock. they responded as below:
The AGP slot on K7VM3 is the standard AGP x8 slot , as long as the VGA card you want to buy is standard AGP VGA card , K7VM3 can support the standard AGP VGA card.
Or , you can double check your question with your VGA card vender before you buy it .
Oct 17, 2010 | Asrock K7VM3 Motherboard
How to increase the shared memory for the internal graphics. i searched everywhere in the bios but i couldn't find a setting. the upper limit is 64 mb and it is currently set to 8 mb. i want to increase...
Your AGP aperture size is 64 MB but your "Onboard VGA Share Memory" may be set only to the maximum available setting in your BIOS. (You may already be at maximum)
1. Highlight "Onboard VGA Share" press <Enter>
2. Change value with [+] or [-]
3. F10 Save and Exit
Dec 14, 2009 | Asrock 845GV (P4I45GV) Motherboard
VGA PROBLEM
Your onboard video might not be working. I suggest getting a Video card and installing that. If onboard video is a must have then you can buy a low video card that fits your mobo, then search online for your mobos onboard video driver and then your onboard VGA should work.
Oct 23, 2008 | Asrock 775i65G Motherboard
VGA Driver
You can go to this link for the driver download for your Onboard VGA http://www.asrock.com/mb/download.asp?Model=ConRoe1333-D667%20R1.0
Hope that helps..............
Aug 27, 2008 | Asrock ConRoe1333-D667 Motherboard
No moniter output
if you mean there is no vga lead connector, there is no onboard graphics, you will need to purchase an agp graphics card
Aug 24, 2008 | EliteGroup L7VMM2 Motherboard
ASrock P4i45GV Motherboard
Hi sandesh8, did you know you can increase the memory size of the onboard AGP card above the 64MB? Page 26 in you're manual. If you install another AGP card into the opened AGP slot, please go to this site & only use the recomended AGP cards in the Asrock list. Click on this link: http://www.asrock.com/mb/vga.asp?Model=P4i45GV%20R5.0&s=478&c=VGA
This is one of very few video cards found on the list with 256MB of video memory.
http://www.amazon.com/nVidia-GeForce-FX-5700-5187-6725/dp/B000RPKI28
Good Luck!
Mike
Jun 08, 2008 | Asrock P4I45GV R5 Motherboard
Asrock P4VM8 Motherboard Logo
256 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
