Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
Apelco 365---power pin connector is rusted and broke
2 Suggested Answers
SOURCE: Apelco 365 fishfinder. Broken
i did the same damn thing and am amazed this question is on the net. i bought a new system but plan on taking it back. the 365 was a pretty nice model and i'm just going to splice it straight to the power supply. but i was lucky, the two pin connector is the damaged one so drilling it out and splicing it SHOULD be easy. well see. at this point i have nothing to lose.
hope this helps.
Posted on Aug 17, 2008
Looking for replacement connectors for the satellite speakers
count the number of pins of your connector so that you will know what to buy, better yet just bring the actual connector to your nearest electronic shop
Nov 08, 2015 | Audio Players & Recorders
How do you check the hall effect sensor on a Amana 34001437 motor?
The diagnosis of this issue can be difficult. There are 2 error codes that are commonly confused. The 3E indicates: Over Current is detected. Motor won't turn. Here are the correct readings for the motor. Pin 1 and Pin 2 of CN9 = 3.0 ohms. Pin 1 and Pin 3 of CN9 = 3.0 ohms. Pin 2 and Pin 3 of CN9 = 3.0 ohms. Any 2 Pins (1, 2, 3) on Motor Connector = 3.0 ohms.Here is the updated motor for that unit.
The part comes with a 365 day, any part, any reason return policy.
Nov 16, 2012 | Amana 34001437 Front Load Washer Motor
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Jun 22, 2009 | Raymarine Boating
Cant find pictures of an Apelco 365 fishfinder? any body have an idea on where to look
Here is one on the cover from a VHS instructional tape showing the 265 and 365. Might be able to blow it up a bit and crop the 365 out....
http://ecx.images-amazon.com/images/I/51EAJS27Z5L._SL500_AA280_.jpg
And, you can go here:
http://www.raymarine.com/SubmittedFiles/Handbooks/Fishfinders/G627296www.pdf
for the 365 handbook to get some pretty fair drawings on the unit. I ran through the pages pretty fast and didn't see any photos but did run across a few drawings and illustrations.
Hope these help. If you can locate a former dealer for them, they might have some clip art from their coop advertising info.
Good Luck....
Apr 14, 2009 | Boating
I require a Manual for a Apelco 365 fish Finder
Check out this site, on here they have a download for the manual you require,
www.retrevo.com/s/Raymarine-465-review-manual/id/556ci073/t/1-2/ - 52k - or go direct to www.raymarine.com
Regards
Alan Hood
ami-man
UK
Mar 12, 2009 | Boating
Raytheon --Apelco 365--fishfinder
For the information of future searchers, I add an OEM type repair that has just worked for me.
Go to the dollar store and pick up any audio lead that has a single narrow pin in the centre. Cut the plastic where the cable enters the plug to expose the end of the pin and wire connection. unsolder the plug and at the same time using the heat from the soldering iron, withdraw the pin from the plastic that is holding it in place. Now you have an unsoldered pin all on its own.
Remove the back from the Apelco 365 and unsolder the wire on the broken pin, (mine was just a push fit). Touch the broken pin with the soldering iron and withdraw it. Insert the new pin, heating it a little with the soldering iron. From the outside of the back case, check the alignment of the pin, making small alterations using a bit of heat. Once satisfied, apply a little dab of crazy glue to fill any gaps around the pin.
Job done. In future use a little Vaseline Petrolem Jelly on the female plug and make sure the plug is square to the back when you insert it, and lined up with the notch at the top.
Oct 15, 2008 | Boating
Apelco 365 fishfinder. Broken pin on power connector
hope this helps.
Jul 27, 2008 | Raymarine A65 Combo GPS...
Searching for wiring diagram
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
May 20, 2008 | Computers & Internet
Power switch went bad. need to know which pins attach to which wires
Looking at the front of PC remove the left side panel. Now looking in at the board. There are two rows of pins in the lowest right hand corner of the board. Your PWRSW is your power switch. Its a two pin connector. The ground wire will be black or white. The ground faces to the right & connects at pin 4 counting from right to left. Power switch takes up pin 4&5.
All done. If tech switched the wires by mistake than flip the connector 180*.
Jan 01, 2008 | VIA ASUS A7V8X-MX KM400 Chipset Ultra...
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
60 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
