Question about Nintendo Wii Console
My 2nd wii controller will not come on but the lights come on for like 2 seconds and go back off. can any one please help ASAP
    Problem Solver:
  • 10 Answers
You must hit the more button then click both the 1 and 2 button a few times then it should connect
Posted on Mar 01, 2009
The remotes flash then switch off, i have synced them again but still wont work.
start with the basics FRESH BATTERIES:
1) Fresh batteries should be in each.
2) Turn on the Wii with Player 1's remote or the button on the console.
3) Open your SD Card cover and press Sync. Very shortly afterward, press the red button on your P1 Remote (in the battery cover). Lights will blink and then will be showing a light in the first square, denoting the connection is complete and it's P1.
4) Do the same as Step 3 for the P2 remote. For the P2 remote, after the blinking, then the second square will be lit, meaning it's P2.
That is the Standard Connection. It is tied to the Wii until it's re-done.
After you attempt to synch them (pressing the red synch button on the wii, followed by the red synch button underneith the battery cover of the wiimote), make sure the wii is turned on and press the buttons 1 and 2 on the wiimote at the same time to have it search for recognized bluetooth devices (ie. your wii).
_________________________________________________
found this article too.
this should help you.. leave a testimonial if I helped.
The first thing I did while the Wii was turned on was that I tried to sync the Wii Remote by pressing the "1" + "2" buttons at the same time. The lights at the bottom of the controller flashed for about 30 seconds, but never received the signal from the Wii. Bummer.
The next step I followed was to hit the sync button on the Wii Remote (Wiimote). Then immediately opened the cover for the opening where the SD Flash card goes and pressed the sync button on the Wii. 30 seconds of flashing, and no result. Double bummer.
Finally, after some Google searching, I found a couple of message boards where people had to press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it. I performed this step and then pressed sync on the Wii Remote. The 2nd controller synced up almost immediately. What a relief!
Apparently the problem lies in the fact that the Bluetooth technology being used has to be manually synced in order for it to connect to the Wii. It does not make much sense at all. You would think they could be pre-authorized in order to minimize time and ease of use. In addition, you really have to be careful that your other controllers are turned on while syncing or else the controller that you are trying to put on channel 3 might end up on channel 2! This happened to me on one occasion.
Good luck with getting your Wiimotes in sync with your Wii. Hopefully this helped!
If this helped you out, please let me know with a comment below!
Apr 10, 2010 | Nintendo Wii Console
2nd controler not logging onto system to allow 2nd player but lights flashing as though trying to log on
There are 2 possible issues.
1.) That second controller is back (not likely since you're more than likely alternating 1st and 2nd controllers)
2.) Your bluetooth pcb chip needs to be replaced inside your Nintendo Wii
It would have to be sent in for repair.
Dec 31, 2009 | Nintendo Wii Console
My wii remote doesn't work!!!
Do you play with the second controller before? If you not the second controller must "bind" to the console. Open the cover in front of the Wii and press the red button there and then press the red button on the controller.
Sep 26, 2009 | Nintendo Harvest Moon: Magical Melody for ...
Wii 2nd player won't stay synced
Re-sync the second controller. Press the red button on the system then press the red button on the controller
Jul 30, 2009 | Nintendo Wii Console
My first guitar works perfect.The second,with my second wii controler does not works.All light flashing on the controler.Nothing happens
I would try putting the controller that you know works into the 2nd guitar. If the guitar works with the good controller then you will know that it's an issue with your other controller opposed to there being a problem with the 2nd guitar.
Please correct me if i'm wrong and misunderstanding you.
I would also make sure that the controller that keeps flashing works without any guitar. Just try playing one of your other games that doesn't require the guitar - that way you know it works. If it keeps flashing like that then we need to advance to some other steps.
I think that the lights flashing probably means that the remote isn't being recognized by the system.
I know that sometimes if the battery is really low the remote will flash and then shut off; I would definately just try replacing the batteries to see if that helps as well. (just to eliminate some of the more simple possibilities)
Let me know how this all plays out for you - I can always dig deeper into the problem if I didn't help you.
Jul 17, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Second remote will not recognize the wii mario kart. Second remote will work with all other wii games, except for Mario Kart.
Had the same problem last night.... Turn off the wii system by unplugging , wait a couple of seconds and plug back in. Next, the front of the wii has a pocket that opens, there is a red button. Put the disc to mario kart in the wii once you see the federal regs push and hold the red button on the wii for 15 seconds then once this 15 seconds is up with the controllers battery case open push the red button to the original controller. All of lights will flash and then stop. Push the red button on the wii console again just once. Then push the red button on the second remote wait till all lights stop flashing push the red button on the console and now they should be married to the wii system. Hope this helps----do you know how to get the volume? We don't have any volume
Jan 24, 2009 | Nintendo Mario Kart (Wii) for Wii
Cant add a controller
I had the same problem and called Nintendo support. They had us unplug the wii console for 30 seconds, plug it back in and start the system back up. BEFORE pressing the A button on the health and safety screen, we needed to take the battery cover off of one remote, press the red sync button, then quickly press the sync button on the front of the wii console (in the front - you have to open the flap). Once the single blue light was on at the bottom of the remote, do the same with the other remote (press the sync button on it and then on the wii console). Then the second blue light should be lit on the second remote. Hope that helps!
Nov 29, 2008 | Nintendo Mario Kart (Wii) for Wii
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
2nd wii remote will not connect with mario play 8
We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
This is from www.nintendo.com/wii :
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Dec 23, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
