Epson Stylus CX6600 All-In-One InkJet Printer Logo
Posted on Mar 01, 2009
Printer continues to tell me low on ink.
I have put in new ink. I have cleaned heads numerous times. Printouts often have partially printed lines of print.
  • Anonymous Apr 01, 2009
    Prints documents with lines missing. Same result for copying. I just replaced the ink cartridge.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
134
Points
I replaced cartridges , error , said to replace cartridges. I then removed the new catridges, and now, can't drop the cartridge back in the scanner.HELP
My printer prints pictures fine but when i print words it dont print black ink just colors why
Black printer ink in Canon Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
We just installed a new black cartridge in Dell printer A940 and it will not print black or copy what is going on
Black printer ink in Dell Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Does not print black. ink tank indicates full and
My kodak 5300 black ink keep saying replace black ink cartridge and i have
Black printer ink in kodak Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Put black ink cartridge in and the printer does not realize it is in the black ink port (this question is for my son that is away at college) get an error message
Black printer ink in Lexmark Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
CoaI have just added new ink and the colors do not print correctly and there is no black ink printing. What is the problem with my printer
Black printer ink in Kodak Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
1helpful
2answers
We purchased a HP Photosmart C4400 series last December 2009. I have just put in a new black ink cartridge and the printer is not printing the black properly, it still very faded. I have put in the correct...
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
All of my printouts are coming out with the top half of every tenth line (about) missing. I have checked the ink nozzles multiple times, cleaned the print head twice and replaced all ink cartridges. I...
If the print-heads are clogged, and your attempts to "unclog" have failed, it's time to responsibly recycle the printer, and buy a new Epson (hopefully, one that uses the same ink-cartridges that you have been using).
1helpful
I have changed all 4 inks and cleaned numerous times but still get loads of white lines running through where it should print solid black.
White lines occur when the print-head is partially clogged. So, if "cleaning" has not helped, it's time to either take the printer to a qualified technician, or to responsibly recycle the printer, and buy a replacement.
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
