Question about Kenmore Washing Machines
Screen says Ld
It seems as though the machine is getting water into the soap cup, but does not flow through to the drum. An error message of L d shows on the screen??
  • 15,935 Answers
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 14, 2010
How do i address a recurrent suds display and subsequent extended rinse cycle on my washer? I have tried using less soap ans always use HE soap. Thx
Unhook the water hoses at the wall and check to make sure the screens are free of debris. The pump is easy to access via the back panel--just two screws. There are blogs available that tell you how to check and replace the pump if necessary. Read all of them before you start. It is often the culprit. Good luck.
Dec 13, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error messsage of L d on the screen
Mar 01, 2009 | Kenmore Washing Machines
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GETTING SL error
Suds lock, use he soap and be sure to use the cup at mark 1 or less. If you have a water softener use a 1/4 less.
Aug 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Amana Front Load Washer Soap Dispenser
I suggest you use soap powder for 'front loading washing machines'. The cartons at the market have them specially marked.
Feb 28, 2008 | GE WSXH208A Front Load Washer
LE Error message
"LE" means overload in motor. When we first got our LD washer we had similar problems. I evenually concluded it was related to adding too much detergent. My suggestion is remove everything and run the machine thru the cycle empty a couple of times with just water. If you cannot get it to run, try draining the water though the drain at the front lower corner. Then using a jug add some hot water in the soap dispenser to flush some of the detergent, and drain that. See if the machine will now run thru a cycle with just water. In our case we were able to get it to run after it sat for a day, perhaps the motor need to cool, I am not sure why. It was tough to get the machine going but once we flushed it and used a LITTLE high efficiency soap with loads we have had no more problems except once when my son did a load with lots of detergent. Then we followed the steps above and were back in business. Hope this help you.
Nov 29, 2007 | LG WM-1832C Front Load Washer
I am getting an error message that says VENTILATE
Try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Nov 07, 2007 | Saeco Royal Exclusive 30153 Espresso...
Water Leak
I have th same problem, apparently a possible cause could be a partially blocked pump filter. Just trying to get infoon where this is and how to get to it though.
Oct 31, 2006 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
22 people viewed this question
Sal De
fordexpert
Robert Rankin
