Question about Kenmore 43142 Front Load Washer
Washer very loud while spinning - Kenmore 43142 Front Load Washer
  • 3 more comments
  • barryt Mar 04, 2009
    Same, very loud when spinning
  • copndaddy Apr 04, 2009
    My Kenmore has the same problem, and leaving 'grease' marks on my clothes. My best guess is the tub bearing has gone out, which does two things. Releases grease and makes a LOT of noise when spinning. Cost is almost $200 for me to purchase a new rear tub which comes with the bearing pressed in. My only problem with this is the fact that I felt like Kenmore should LAST longer than just 5-7 years before a major issue such as this. What happened to appliances lasting 20+ years?
  • jerry03755 Apr 10, 2009
    Very load when spinning and leaves grease spots on the clothing.
  • Anonymous Apr 18, 2009
    While spin mode you hear the grinding of bearings.
  • lanek48 May 09, 2009
    Loud noise when spinning and oil on clothes.
    Sears repairman said with parts and labor it would cost 1035.34 to fix this problem. The washer is 5 & 1/2 years old and we paid $599.00 for it and bought an extended warranty for 5 years for another 199.99. The washer lasted 6 months past the extended warranty. I am concerned with buying another front load washer from sears or if all front load washers have similar problems.
    Problem Solver:
  • 8 Answers
Bearings packed up.
Posted on Mar 13, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Kenmore 43142 Front Load Washer Logo
226 people viewed this question
Sal De
fordexpert
Robert Rankin
