Question about HP Pavilion a1700n PC Desktop
Replace ata drive with eide
HP Pavillon A1700n. My ata internal drive died. I purchased an eide drive and the ribbon cable won't stretch to the bay. what can i do
  • 239 Answers
You can purchase a longer ribbon. otherwise there is nothing else you can do.
Posted on Mar 01, 2009
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
I have the rocketfish hard drive enclosure and when i started to use it on the my MacPro it was working fine then it just stopped working and stopped being recognized.
The internal connection of the hard drive has probably become dislodged. Open it up and reconnect it firmly. If that does not resolve the issue the drive may simple have died (the hard drive, not the enclosure)
Apr 22, 2011 | Rocketfish 25" EIDE ATA HARD DRIVE...
The cd/dvd drive is not recognized on HP Pavillon laptop.
If you recently removed or changed a drive from one of the drive bays, you may have to make one fo the drives the "master' and the other the 'slave'.
If you only have one drive and it is set to 'slave', it will probably not recognize the drive.
there is a small set of jumpers on the back of the drive, near the ribbon cable connection. you will need to look on the drive for the settings for master / slave, and set the drive appropriately.
May 19, 2010 | HP DVD DRIVE DVD Drive
The hard drive died, can I install Western Digital Scorpio Hard Drive - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal (WD1200BEVE) to replace it
You should definitely try out if it fits inside the bay first.
The original drive in the M55-S135 has a height of 8mm and the WD1200BEVE is 9.3mm. This is not a big difference and may pose no problem, but you would like to have all covers close properly later, I assume.
Other than the slightly larger physical dimensions, the drive should be fully compatible with the laptop.
Feb 12, 2010 | Toshiba Satellite M55-S135 Notebook
How can I replace my 30GB ultra ATA EIDE HDD with
Purchase a solid state drive, 2.5" for laptops 3.5" for desktops (or use an adapter for notebook drives with a 2.5")
Connect your IDE cable (and power cable on desktops) to the drive, install Windows and you are done!
If you want to keep your existing data, get an external enclosure for the appropriate sized disk and use a program like Norton Ghost or Acronis True Image to clone the existing drive to the new one, then swap the two drives (SSD from enclosure to internal, other drive out to enclosure)
Comment if you need more information!
Feb 06, 2010 | HP 100GB Ultra ATA/100 EIDE hard drive -...
Can I replace an ultra ATA drive with an EIDE drive?
Yes there are several ways.
1st is there a spare IDE socket on the motherboard?
If not you can get a IDE to SATA convertor thet plugs in the back of the drive. or you can get a convertor for a SATA drive to make it IDE compatable.
Sep 20, 2009 | HP 100GB Ultra ATA/100 EIDE hard drive -...
Hard drive
According to,1000000973,10004197,00.htm this tower has Serial ATA, or SATA. Just to confirm, you can easily pop open the case and take a look at the hard-drives. If you see a wide thin ribbon-like cable connecting to your hard-drive then you need an Ultra ATA (or just ATA or IDE) drive. It looks like this:
If a thinner red cable connects to your drive, then that is SATA. It looks like this:
May 13, 2008 | Dell Dimension 8300 PC Desktop
Whats the largest replaement HD I can put in my Presario
The HD capacity is defined by the bios software in the computer, if HP/Compaq tells you that 80Gb is the maximum capacity, then I think you should believe them, after all they should be the first one interested in selling more high price products, go for the 80Gb is .
May 03, 2008 | Computers & Internet
Difference between ata and sata hard disks
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Feb 18, 2008 | Highpoint Technologies 1 Bay e.SATA...
HP Pavilion a1700n PC Desktop Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
