Question about DISH Network IR Remote Control
Reciver goes off air
When i cut the reciver on it keeps going to off air.
  • 374 Answers
Sounds like you have a notorious 381 receiver. If you are unable to get it back have it replaced.The 381's they are sending out now have a newer software version also that will alleviate issues. Thanks for using Fix Ya.
Posted on Mar 03, 2009
Air con keeps turning its self on and off ???
Could be low on freon therefore the low pressure switch cuts it off. Once the pressures get stablize it will cut the unit back on until it goes off on low pressure switch once again
Jan 11, 2014 | Heating & Cooling
Tip
How to keep your cutting boards from warping
To keep a cutting board in good condition never rub it with vegetable oil as it will eventually go rancid. Most cutting board conditioners seem to be top secret as they will not divulge what they have in it. Upon researching the internet i discovered that you could use paraffin or a food grade mineral oil. Mineral oil although a byproduct of gasoline manufacture is not toxic as almost all other petroleum products are. Brake fluid and transmission fluids are based off of mineral oil... but it is fine orally used for medical purposes as well. Cutting boards need to be turned over periodically and oiled monthly especially as the weather turns to wet weather... or as it goes back to cold dry air.
on Oct 19, 2013 | Cooktops
My reciver keeps shuting off and saying protect when nothing conected to the reciver and it was playing music perfectly at low volume setting and then cut off
The Amplifier has a Fault and is shutting down to protect itself. Repeated cycling of this will cause a total failure in the Amplifier.
If you haven't got the Technical ability to have a look at it yourself then I suggest you take it to a service engineer or wait for a total failure and scrap it.
Jun 04, 2011 | Sony STR-DG520 Receiver
Why is the heater in my whirlpool acpe102ps0 portable air conditioner/heater blowing unheated air with the heater setting on?
the unit goes into defrost every hour or so this could be the reason you are reciving untempered aire
Mar 05, 2011 | Whirlpool Heating & Cooling
AC WORKS FINE HEAT COMES ON BUT WHEN TEMP IS REACHED FAN NEVER GOES OFF AND TROUBLE WITH HEAT COMING BACK ON
When temp reached to thermostat level heatewr only will cut off not the blower. And secondly all thermostat at heat stage will cut off at the end of +2 degree and cut in starting of -2 degree.
E.g; If you keep 30 degree heat it will cut off at 32 and cut in 28 degree.
Dec 07, 2010 | Crosley CAE12ESR Air Conditioner
Cars start but 3 secons after the engine die
mcdevito75 here, 3 seconds after the car stars I'll bet the idle goes way high, if so the fast idle swith / motor could be bad. Or if the idle goes way low, it could be the air Idle, sensor/ motor going bad. Either way have your local repair shop run a scan and see.
Jun 14, 2010 | 2001 Dodge Durango
Infinity tss-1100 sub problem
hey buddy, I have the same system, and although I haven't experienced it on this one, I had the Harman Kardon equivalent to the TSS-750, and the sub did this same thing. It was a loose RCA connection, and, as I was well outside of warranty, I took the amp out of the back and just re-soldered the connection myself. It now functions flawlessly for my bedroom setup. I hope you get it all worked out on your system! I can't imagine using this awesome system without its deep notes!
Jan 07, 2009 | Infinity TSS-1100 System
Mitsubishi MSH12TH heat pump air handler 110v
Wireing this type AC with the wrong voltage, will damage more than the circuit boards. I think the installer wil need to be responsible for the damage he created. The factory will also try to get out of the replacement because of the installers lack of know how.
Oct 20, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Direct tv cable
ok if its only the rf cable and the ac cord yes you can do it your self.you have one cable out from the sat reciver going to the dish. Find an area that the pooch didnot chew through cut off the bad part of the wire. find the wire that goes to the tv set. if its the coax disconnect from the reciver on both sides and go to the store and buy a new cable (unless you have coax wire and know how to put on f fittings) also while your there buy a small extenstion for the other cable you cut. also your gonna need a a female barrel connector as we;ll as an rg6 type rf fitting for the end you cut. have the guy at the store explain to ya how to put on a f fitting. If the ac cord was chewed buy a simple cheap extenstion cord too. Go home and first put back on the cable you took off the output of the sat reciver and the other end to your tv set. then put on the f fitting the guy explained to ya how to put on and then install the barrel connector then the short extention wire to the other side of the barrel connector then the other end of the rxtenstion cable to the sat output. Now if the power cord is chewed im surprised the pooch is not fryed!!!lol Simply cut off the bad part take the extention cord and cut of the end you dont need take off about 1 and a 1/2 inches of the insulation on bothe parts(reciver and cord) twist together and tape separatly or use wire nuts on them . then you are good to go. BUt one more little thing are you using video cables between the tv and the sat. reciver?? well why didnt you say so LOL simplyu pull out of both ends and go to rat shack or something like them and buy an inexpensive pair of cables and remeber yellow is always video red is alway right audio and white is left audio Hope this clears things up for ya.!!!!
Apr 02, 2006 | RCA DRD450RG DirecTV DTV Receiver
DISH Network IR Remote Control Logo
43 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
