Question about Kirby G6 Bagged Upright Vacuum
Axle bracket problem
The axle bracket with spring/ foot pedals to control heighth adjustment keeps coming off the axle rod. Where can I get a new bracket or rod. I'm not sure if both need to be replaced. It may be a packaged assembly. This is for a 2001 G Limited edition Kirby.
  • Kirby Expert
  • 324 Answers
You can find parts HERE. I do not think you need new "Ratchet Lock Assm." unles yu lost it (I have never seen one broken). Make sure you have the Spring and lubricate it well (do not use liquid lubricants as they will leak on the carpet).
God Luck
Posted on Mar 03, 2009
I need a you tube showing me how to replace the handle release. when I pick up the vacuum by the handle the vacuum head flops down
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Feb 15, 2016 | Riccar 8000, 8900 Series Metal Agitator...
The pedal on my hoover is stuck
Your foot pedal is likely not snapped on to the axle assembly all of the way.
Oct 16, 2014 | Sebo X4 Extra Bagged Upright Vacuum
DYSON DC25 FOOT PEDAL PROBLEM
sorr this is all i can find
Jan 02, 2013 | Dyson DC25 Vacuum
When you turn the sewing machine on it constantly keeps on going almost like you have your foot on the pedal all the time the machine is a contessa 410 model
the foot pedal controls the voltage to the machine. If it is running to fast then the foot control is bad
Apr 18, 2011 | Vacuums
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum before and my wife had the same issue. The neutral/drive pedal just fell out so I figured I would give it a shot to see if I could fix it and quickly figured out the 3 screws in the bottom plate for the drive unit wasn't the answer.
I was able to figure things out out after I found a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive G6 558499A
Here's how to get to a point that you can get these two parts in/out of the machine.
- Remove bag and fill tube from handle and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws at the handle fork plate (these have loctite on them so needed a socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate vie the screw with the power cord anchor and screw by the Pedal Cam For Neutral Drive. Note release plastic tab in slot in the center and lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the power drive assembly so I could figure out how to put the dive assembly back together. The pressed on arm that drives the cam assembly had pulled of the pedal shaft so this also made it easier to fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside.
I assume at this point you could loosen the screw (don't remove it, it's the only one with a star lock washer on it) on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam out and a new one in if you can get the part and replace it. The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take the power drive assembly out:
- Remove the 4 screws from the Cover Shell assembly - the metal top part. You do not need to remove the hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket assembly that has the handle attachment and forward/reverse switch. It attached by two wires. I only disconnect one and swung it to the side.
- Snap off the the on/off switch and disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now drop out the bottom.
I just put the spring washer and arm back on the shaft and reassembled. I'll see how long that lasts before before buying the new part.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Kirby G6 Bagged Upright Vacuum Logo
129 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
