Question about Dometic Rooftop RV Air Conditioner
Air conditioning won't work. Maybe no ground
We have a 2006 Dutchman 5th Wheel Toy Hauler. We haven't use the it for a long time. We ran the lights and a/c for about 4 or 5 hours and than all of the sudden it turned off. The lights and a/c came back on about 5 mins later than quit. The lights and a/c came on again ran another 4 or 5 hours and than lost the same lights and air conditioning again. Now the lights and a/c won't come on at all. When we grounded the control panel for the a/c we found that the air will come on but the lights won't. We suspecting it might be the ground? We should be look for the main ground. What do you think is happening? Thank you
  • Farley Redfield
    Farley Redfield May 11, 2010
    Sounds like your on the right track but let me be clear DO NOT TRY TO FIX A GROUND WITH ANY POWER TO ANYTHING. This is more dangerous or it can be than working on the HOT side of a live circuit.
    Take a VOM and check across your power AC LINE coming into the BOX feeding everything. BE VERY CAREFUL! A loose ground on 110 IS looking for a ground and a spark or snap if your not expecting it can cause you to get a cut or worse. (The main thing is are you using the inverter to power the lights or AC power)? Could be that your battery is down and you need to clean up the terminals to allow it to charge and put your lights back on assuming they are on DC POWER. Check your inverter mfg recomendations. Hope this helps and you can give me a good word \here. Let me know if I need to be clearer on any of this. OH yes if in doubt about which power your lights are using remove the bulb and read what it says AC bulbs have rating in AC and DC in DC. They are NOT interchangable.
  • 22 Answers
Open your elctrical panel on your fifth wheel and make sure the wire terminals are tight comming in from the electrical power cord.
There could also be a issue with your power converter. Try turning your circuit breakers off and back on.
Posted on Mar 31, 2009
I need an owners manual for a 2011 Weekender. It is not a 5th wheel and am not sure or manufacturer maybe skyline It is either a mmodel 14 RB or a Sportsman weekender
The manufacturer was Skyline who sold operations to Evergreen who sold operations to Dutchman who is owned by Thor.
So I recommend contacting your local retailer or try your luck with Thor using this link:
https://www.thormotorcoach.com/contact-us
Jul 16, 2017 | RVs
Flashing 4wd and steady abs light on ford escape
I have a 2005 Ford Escape and have this problem. I can tell you that if the light comes on every .8 miles and blinks for 8 times, learn to live with it. After taking to dealer when it first started in about 2008, having the tone ring changed on the CV's for the tires, after been told maybe an alien lived in there....the light sell happily blinks on.If it comes on and stays on I would worry more than if it blinks intermittently. Mine has what they call "Intelligent 4-Wheel Drive" [which must be an oxymoron], but still has the 4X4 light to indicate when supposedly it switches in to 4-wheel drive according to driving conditions. Certainly if you haven't noticed any other abnormalities with how the vehicle drives this could very well be the culprit.Hope this helps.
May 17, 2012 | 2006 Ford Escape
How do I check to see if my motor is locked up before I take it to the shop?
The easiest way to check this condition is to put your bike into a high gear (4th, 5th, or 6th, if you have it) and roll the bike forward. You don't need or want to have the ignition key turned on for this. If the motor is frozen, the rear wheel will lock up. If the motor is free, the rear wheel will slowly turn the engine over. The higher the gear, the easier a time you'll have of pushing the bike forward. Also, if you remove the spark plugs before you try this, the engine won't be creating any compression, and that will make it much easier for it to turn over, too.
If you haven't run the bike in a while, squirting a little bit of oil down each spark plug hole after you pull the plugs will also lubricate the sidewalls while the rear wheel moves the pistons up and down. That's a nice gentle way to get things moving again while minimizing cylinder wall scuffing.
May 11, 2011 | 1985 Yamaha XJ 700 X Maxim
Same problem freezer is ice cold and the fridge is warm.
Make sure that the knob that controls the opening of the vent so the cold air in the freezer get to the refrigerator is operating. If it does, I don't see any reason why the refrigerator should not work.
Jun 30, 2009 | Dometic NDR 1292 Refrigerator
2003 Thor Tahoe 5th wheel toy hauler 33TB
http://www.thorca.com/service.htm
Here is the best I found. There is a generic owners manual for download and an owners number you can call for additional help.
Jun 28, 2009 | Sport & Outdoor - Others
Dometic Rooftop RV Air Conditioner Logo
264 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
