Question about Refrigerators
Loud banging nois when compessor shuts down
Hotpoint 20.6 ctx 21BA what do I have to do to get to the compressor I would like to see if bolts are loose or what?
  • frank10927 Mar 05, 2009
    thank's for the comeback,I'd still like to know how do I get to the compessor.Thank's again
  • 400 Answers
The banging noise usually occurs when the internal mounting springs are weak. You cannot get to them, they are internal. This causes a banging noise when the fridge comes on or switches off. It can also happen when the starter relay on the compressor makes a bad connection and therefore the compressor does not get immediate good power causing a stutter.
Posted on Mar 05, 2009
  • Shane Seaman Mar 05, 2009
    The compressor is at the back of the unit and you may have to remove a grill cover (about four screws) the compressor is the black dome/ball shaped number which takes up most of the space in this area
When defrosting, what causes loud banging noises?
Hello David;
My name is Peter. I am a retired field service refrigeration technician.
The noise is coming from one of two places.
1.) Freezer Fan - The fan may be hitting ice. After defrosting the noise will disappear.
2.) Compressor Flapper Valves - Remove the cover to expose the compressor. Plug the unit back in. If the compressor starts jumping unplug the unit. Check the rubber bushings where the compressor is bolted down. Are the bolts loose? Is the rubber torn off? If the compressor is secure, then you have a bad compressor.
Dec 30, 2014 | Freezers
Knocking noise
2545 is a piston compessor if so you've got a busted rod on one of your cylinders , this will fail catastrofic and break out side of compessor but if caught early can still be rebuilt with a few new parts
Mar 18, 2014 | Ingersoll Rand 2545 pump,air compressor
Hotpoint ffp187b loud noise from appliance
Where is the noise coming from? The front, back, top, or bottom? Is it a bump, thump, bang, clang, or rattle? Does the sound happen at regular intervals or randomly? It could be the compressor bushings going bad, causing the compressor to bang around.
Mar 25, 2013 | Hotpoint Refrigerators
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
Compessor trips circuit
IT SOUNDS LIKE YOUR COMPRESSOR IS NOT UNLOADING WHEN IT SHUTS DOWN. YOU SHOULD HEAR AN AIR RELIEF SOUND TYPICALLY ON THE SIDE OF THE PRESSURE SWITCH WHEN IT SHUTS DOWN. ITS A SMALL VALVE WITH A TIRE VALVE THAT THE LEVER HITS AND RELIEVES THE PRESSURE FROM THE DISCHARGE LINE AND THE TOP OF THE PISTON.
YOUR CHECK VALVE COULD BE BAD LETTING PRESSURE BACK UP BUT IT WOULD BE BLOWING AIR OUT ALL THE TIME WHEN SHUT DOWN.
IF YOU THINK THE VALVE OR SWITCH IS WORKING AND WANT TO CHECK IT, LET THE COMPRESSOR BUILD UP AND SHUT DOWN, LISTEN FOR THE AIR RELIEF,IF IT DOESNT THEN CRACK THE DISCHARGE LINE AND SEE IF THERES ANY PRESSURE, MANUALLY RELIEVE THE PRESSURE THEN USE SOME AIR AND SEE WHAT HAPPENS. REPAIR VALVE ON THE SIDE OR CHANGE PRESSURE SWITCH $30-40.00. HOPE THIS HELPS. PLEASE REPLY. JODY
Apr 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Loud bang
John,
What you are hearing is popping caused by thermal expansion inside the evaporator enclosure during its' defrost cycle.
Depending on your make and model, it'll go into defrost every 8 to 12 hours of compressor "run time". That is, the defrost timer "monitors" how long the compressor runs and after it accumulates the pre-set "run time", the timer then shuts the compressor off and initiates its' programmed defrost routine. This routine lasts for 20-30 minutes, or until the defrost thermostat opens.
The defrost routine sends 120 volts to a heating element in the evaporator compartment which gets red hot. This sudden temperature change (from below freezing to warm) causes the cabinet to expand slightly. That's when you hear the "Pop".
I hope this helps, John. Thanks for using FixYa, and don't forget to rate my answer.
SG
Apr 02, 2009 | Freezers
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Kenmore elite refrigerator/freezer loud banging
it is compressor shutting off,not much you can do to fix it.you can try changing the snubbers that hold it in place but most likely you will still hear it clunk.
Mar 07, 2009 | Kenmore Refrigerators
Knocking/banging sound on compressor start up
Check the compressor mounts. They are usually springs mounted with rubber. If they are two loose the compessor wil hit some other metal part when starting up. Shakle it and see what it is hitting. Ajust accordingly.
Dec 27, 2008 | Refrigerators
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Refrigerators Logo
231 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
