Question about LG DLG5932W Gas Dryer
I HAVE A GE GAS DRYER LESS THAN ONE YEAR OLD. IT TUMBLES, BUT WILL NOT HEAT UP. IT SEEMS TO TRY TO HEAT UP, BUT SHUTS DOWN IN ABOUT 30 SECONDS.
    Guru:
  • 462 Answers
These are the standard things to check out a gas Dryer that is not heating.
If you feel confident!
Trained people like myself make mistakes too but it usually happens when we get too friendly with what we are doing and become complaisant. It can really be bad if a non trained person is jumpy and doesn’t know safety about when or what is suppose to be happening first, second… Or how to arrive at what should be happening and it isn’t. But at this point if your jittery and don’t feel confident, stop and let someone trained handle the rest.
Key to all modern flame (fossil fuel) appliances is a need for ignition. The 2 most common ways to ignite the flame are:
1 Spark (where there is a spark generator that when directed to the area of the flam ignite the main burner or in some cases a pilot flame) and,
2 Direct ignitions, which most commonly uses a silicone or nitride igniter that glows brightly to ignite the flame.
Common to both of these ignition systems is:
Safety first: always a way to prove that the flame is there and burning.
Here after I will address mostly the Hot Surface Ignition (the orange or direct type of ignition), because the spark ignition type of units have been phased out.
Do you get a "glow" the glow (orange in color) is for the gas to be ignited.
No glow indicates the igniter either has a no voltage problem or the igniter is burned out.
No power should flow to the gas valve if you have no igniter. However, you may smell gas and have no igniter intermittently. This can be normal as some safety systems will allow the gas to flow to the igniter area for a few tries at ignition before locking the valve off.. To be safe always turn off the gas to the appliance, burner, or at the gas valve. I will assume you know how to do this if you don’t then let someone trained handle the rest.
If your ready to proceed:
Confirm power to the gas valve area 110V usually and keep in mind that the dryer has to be running at this point on most all dryers. There is little reason for the burner to come on if the dryer is not running, right?
If you have voltage to the gas valve area check the voltage at the ignition directly. Just to be sure your not in a lock out, mode remove power from the appliance for 2 to 3 minutes reapply power and restart and try the dryer (still with gas off). If no power still to the gas valve/igniter there the problem is somewhere other than the area your in. If you have voltage the problem is probably the igniter. The next step would be to check the voltage to the igniter terminals. Voltage there is almost a guarantee the igniter is out. Look for the way the ignition was installed originally and reverse the process getting the igniter in hand so you can be sure you get the correct one for replacement. It may come out in pieces just take all of them you can to keep the area clean. And vacuum opr blow out the rest with compressed air.
If you don't have 110 Volts the problem is in the controls. The electronic ignition safety board, fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. If you check all the controls and have power to the Ignition board where it is suppose to be with it running then it must be out. Other wise you will have to jump around each safety/control to verify which one is open. Also you may have top stop and restart the drier for each component test to keep from locking out the safety on the ignition board.
Clean the duct out while replacing the igniter if so because the main thing that causes igniter burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps. With any luck all you need is a new igniter
Thank you and good luck.
Also you should check for a kink in the exit hose diminished air flow through the machine. And I assume you mean the heat shuts down and not the whole machine?
Posted on Mar 23, 2009
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
I have a 6 year old maytag gas dryer , model SDG515DAWW. it isnt heating and drying the clothes properly. I opened the bottom panel and see the ignition components. The ignitor glows after 20 - 30 seconds...
Your ignitor is going bad...yeah it sounds crazy, but change it and you will be working again...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 17, 2010 | Dryers
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
DPGT750GCPL heat issue
What do you mean by "215 or 20 seconds"?
May 11, 2017 | GE Profile Harmony DPGT750GC Gas Dryer
No hot air
If you have a pilot light (small flame) you can try to re-light it by turning the knob on the gas valve to the pilot position and pushing the knob down while lighting the pilot, you may have to hold the knob down for up to 30 seconds before releasing it. The pilot should stay lit and then turn the knob to the on position. If the pilot will not stay lit or the main burner will not light it could be the gas valve or the temperature sensor.
Jun 11, 2008 | Dryers
LG DLG5932W Gas Dryer Logo
307 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
