Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Error99 appears on lcd screen
Error 99 appears on screen owners manual sugest turn camera on off or reset battery have done this does not fix problem.
    Problem Solver:
  • 17 Answers
Error 99 is a lens issue, try this.
Posted on Mar 16, 2009
My Canon camera has an error screen that comes up every time I try to take a photo. It's error99. Do I need a new battery?
Not necessarily. This error is a general error for things that do not fall under any other category.
Try resetting the camera, as well as removing and replacing the lens.
Mar 12, 2011 | Canon Cameras
Error99 appear on lcd
clean the lens contacts and body contacts with lens and try again. Otherwise send it to a technician for a service.
Apr 06, 2010 | Canon Digital Rebel / EOS-300D Digital...
I have a new Rebel xs kit, and after 20 shots, I got the err 99. I did all the above, that is from cleaning contacts to everything possible procedure mentioned in this forum. There are few things that I...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
How can I solve an error 99 problem in my Canon Rebel xs
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99 comes on after I have taken a few pictures. I have tried cleaning with eraser as people have done and it still comes up with message.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Jul 14, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99
i had the same problem and i found this guide online fixed my problem
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Apr 19, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Error99... pls help!!
here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
Feb 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
320 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
