Question about Sunpentown SB-620 Magic Clean Bidet with Dryer
Magic clean Bidet SB620 Unit stopped spraying water. Screen is clean. Water pressure is same as last three years I have owned unit. Water valve is on. I looked inside and it is very complicated so I put the lid right back on. I can't fix this with just common tools and common sense. Where can I contact repair service? Thanks.
  • jetman4u Mar 10, 2009
    Same problem. Just up and quit one day. Played with the unit and found that no water preasure was getting to the holding tank. Water inlet screen seem to be clean, but still no water was getting into unit. I removed the screen and everything started to work again. We have high calicum in our water. Even though the screen looked clean, it was pluged. Now my problem is where do we get new screens?
SOURCE: SB-620 Magic Clean Bidet
CALL 800-681-0753 FOR PARTS
WWW.BIDET1.COM
Posted on Feb 26, 2010
Can anyone help fix this washers spray function?
is it getting enough water in tub? try extra water button and see if then it works. if that makes it work, then water pressure sensor may be an issue
Apr 01, 2015 | LG WM-2032H Front Load Washer
Stops running in middle of cycle and displays an f on the screen
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • 3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Thank you !!
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need help
check the water valve (which supplies water to the unit) is open. if so, the solenoid operated valve in your unit would have failed. Get it replaced. May sound silly, but try switching off the power to the unit, wait for 2 mts and switch on. All these microprocessor controlled devices hang at times like our computers. Recycling the power works sometimes
Mar 19, 2010 | Sunpentown SB-620 Magic Clean Bidet with...
My admiral washer does not stop filling with water and it is not the hose,
could b faulty water valve. to check if it is the valve start fill cycle and when u hear water going into unit turn off power at power point,this should shut water off immeditaly. if water still comes into unit with power off it is the water valve. if it the water stops then the problem is the pressure switch or pressure switch hose.please reply if u need more help
Mar 14, 2010 | Washing Machines
My washer starts and the water starts coming in, then it stops and an "F" shows on display and beeps...HEEELLLLPPPPP!!!!
Hi There
I want to say is Merry X-Mas and Happy New Year. I have found what you need hope this will get you in the right direction.
F/H No water detected entering machine or Pressure switch trip not detected.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Thank you for writing to fix ya. Let me know how it went.
Best Regards Richard
Dec 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Samsung VRT Steam FabriC Softener not dispensing
My fabric softener intermiitently was left with clear water in the tray. The serviceman replaced the tray which did not fix the problem, he then replaced the valve assembly. That fixed the problem for about a year and now I am experiencing the same problem. Being the unit is now out of warranty, I purchased a valve assembly and replaced it but what I found in the process was that the real problem was that after removing the filter screen where the hose connects I found a SECOND mesh filter that was plugged up. I removed it with a needle from the edge so I didnt damage the screen. I think you could also just used a spray bottle with some water and a Q tip to clean. I wasted $50 on a valve assembly, but I did discover this second filter screen that is not mentioned in the user manual. Hope this helps someone because I have not seen this solution posted anywhere.
Jul 26, 2009 | Samsung Washing Machines
I had same problem. Reolace the magnetic reed switch in the level sensor unit. It is a float with a magnet inside which goes up and down a shaft activating the reed switch inside the sensor shaft. The switch is just an ordinary normaly open glass encapusated magnetic reed switch. Carefully hack out the original with a suitable tool but not a drill and slide in a new one. If you can't change the sensor just pull out the power plug and re-plug . This usually resets the circuit. Not a real fix just a temporary work around. Much easier if you can just find a replacement level sensor unit. Good luck.
Oct 17, 2008 | Sunpentown SB-620 Magic Clean Bidet with...
Error code HF
Or
Verify CCU operation.
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-H code and water won't stop
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Nov 27, 2007 | Kenmore Elite 45986 Front Load Washer
FH error - how to clean water inlet screen?
open the top of the machine and check the hoses to the pressure switch
looks like this
http://store.4appliancerepairparts.com/servlet/-strse-6581/134438301-Water-Level-Pressure/Detail
Nov 12, 2007 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
249 people viewed this question
Top Sunpentown Washing Machines Experts
Richard Roth
Richard Roth
Are you a Sunpentown Washing Machine Expert? Answer questions, earn points and help others
