Question about Canon imageRUNNER 5570 Copier
Intermittent E0061-0001 on a IR6570 canon
Tuned off pont.control,same porblem.replaced laser unit,DC cont.Bd. and HVT. now the code comes right after copies are complete,with a long "wait"message on the display.could pot control sensor be the problem even thou I had turned it off. also getting intermittent background on some copies
  • Canon Expert
  • 1,326 Answers
Have you tried to replace the Primary Charge corona unit? How about the rear block for the primary? Try to blow it out.... I did see in the book to try to run DPC in service mode... I also remember on older Canons that some times the wire ties may cause a problem... Also, you say that you are getting background... Is the laser good? Come to think of it I had a IR-5000 do the same thing and it turned out to be the rear corona block for the primary & transfer corona units... Good Luck
Posted on Mar 02, 2009
How to solve error 100-0001
Code E100-0001 Description The BD signal is not detected 10 times or more within 10 msec in 5 msec after the generation of the laser drive signal Causes The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The laser scanner unit is faulty. The DC controller PCB is faulty. Remedy 1. BD PCB Try replacing the BD PCB. Is the problem corrected? YES: End. 2. Laser scanner unit, DC controller PCB Try replacing the laser scanner unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Dec 05, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
CODE ERROR 100 SHOVING IN I R 3300 CANNON XEROX
You may need to replace the laser, it may have failed, this is from the service manual
E100
0001 The BD signal is not detected 10 times or more within 10 msec in 5 msec
after the generation of the laser drive signal.
0002 While the laser is ON, the BD signal cycle is outside a specific range 20
times or more continuously.
0003 While the laser is ON, the horizontal sync signal cycle is outside a specific
range 20 times or more.
Main cause The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The
Action
1. BD PCB
YES: End.
YES: End.
anual.
Aug 30, 2014 | Canon IR 3300 Digital Copier
Code erro e000061-001 e e000061-002 ir6570
canon copiers model ir6020i show code E000061-0001 what happen wiht my copier and how to solve this problem?
Apr 26, 2011 | Office Equipment & Supplies
Error e0610096 in canon 1140
The Service manual say:
E061 is an error code associated with the mechanism controlling the surface
potential of the drum, and points to the following:
(The notation "xx" of detail code indicates the color of the developing
assembly; e.g., xx=01: M, xx=02: Y, xx=03: Y, xx=04: Bk.)
Detail code: 0096
Description: Vd2 is 550 V or less.
Possible cause: The Vd2 lower limit is reached
Step 1
Checks: Is the setting of
COPIER>ADJUST>V-CONT-M/C/
Y/K in service mode identical to the
settings recorded on the service label?
Yes/No: NO
Action: Enter the settings from
the service label newly.
Step 2
Check the detail code in service
mode (COPIER>DISPLAY>ERR).
Is it 0000 or 0001? YES Go to step 3.
Is it 0010? YES Go to step 4.
Is it 0020? YES Go to step 5.
Is it 0030, 0031, or 0032? YES Go to step 9.
Is it 0040? YES Go to step 12.
Is it 0050, 0051, 0052, or 0053? YES Go to step 16.
Is it 0070, 0071, xx80, or xx81? YES Go to step 19.
Is it 0060 or 009x? YES Go to step 20.
Step 3: Potential sensor unit
Checks:
Turn on and off the power switch.
Does LED1 on the potential
measurement PCB remain on
during potential control?
NO - Replace the potential sensor unit.
YES - Check the wiring from the
DC driver PC to the potential
sensor. Turn off and then on
the power switch; if the error
is indicated once again, go to
step 2.
Step 4: Pre-exposure lamp
Checks:
Does the pre-exposure lamp turn
on during copying operation?
NO - Check the wiring from
the DC driver PCB to
the pre-exposure lamp;
if normal, replace the
pre-exposure lamp.
YES - Check the potential
sensor unit. Turn off and
then on the power switch;
if the error is indicated
once again, go to step 2.
Step 5: Primary charging assembly
Is the primary charging assembly
connected properly?
NO - Connect the assembly
properly.
Step 6: Primary charging assembly
Is the primary charging wire
broken or soiled?
YES - Clean or route the charging
wire once again. Turn off and
then on the power switch; if
the error is indicated once
Step 7: Primary charging assembly
Are there traces of leakage on the
primary charging assembly?
YES - Replace the primary
charging assembly.
Step 8: High-voltage cable
Is there electrical conductivity
from the primary charging wire to
the high-voltage transformer
(HVT-DC)?
NO - Check the primary highvoltage
cable.
YES - Replace the HVT-DC
PCB. Turn off and then
Step 9: HVT-DC PCB
fitted properly?
NO - Fit the assembly
properly.
Step 10: Primary charging grid plate
Is the grid plate of the primary
charging assembly mounted
properly?
NO - Mount the grid plate
properly.
Step 11: High-voltage cable HVT-DC PCB
Is there electrical continuity from
charging assembly to the highvoltage
transformer (HVT-DC)?
NO - Check the grid highvoltage
cable.
Step 12: Post-cleaning charging assembly
Is the post-cleaning charging
assembly fitted properly?
properly.
Step 13: Post-cleaning charging assembly
Is the post-cleaning charging wire
broken or soiled?
YES - Clean or fit the charging
wire properly.
Step 14: Post-cleaning charging assembly
Are there traces of leakage in the
post-cleaning charging assembly?
YES - Replace the postcleaning
charging
assembly.
Step 15: High-voltage cable
assembly to the high-voltage
NO - Check the post-cleaning
high-voltage cable.
Step 16: Laser exposure system
Is the movement of the laser shutter
normal?
NO - Check the shutter
assembly
Step 17: Laser exposure system
Is the dust-proofing glass or the
bending mirror soiled?
YES - Clean it.
Step 18: Laser exposure system
Is the laser power normal? (See the
descriptions given for how to adjust
the laser power.)
NO - Adjust the laser power.
If output is absent,
replace the laser unit or
the laser driver.
YES - Check the
photosensitive drum for
grounding; if normal,
replace the
photosensitive drum.
(After replacement,
execute the work under
II. C. 2.)
Turn off and then on the
Jan 13, 2011 | Canon CLC 1140 Copier
I got canon ir1600 i am receiving an error msg as error 100
as sm -
E100
When the scanner motor is started up, the BD input signal does not arrive
within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and
fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal
cycle is not within a specific range (±2%) for an equivalent of 10 mm (print
distance).
cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or
the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause
The wiring is faulty (short circuit, open circuit). The laser scanner unit is
faulty. The DC controller PCB is faulty. The drum unit is not installed.
Remedy
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Jun 04, 2009 | Canon ImageRunner 1600 Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Error code E000025-0000
1) Drum unitIs the drum unit installed in host machine?
2) Connection
YES : End.
Good Luck
Feb 03, 2009 | Canon imageRUNNER C3200 Copier
Canon IR2020 photocopier system error E100 how can I fix this problem
BD detection PCB failure
The BD detection PCB is faulty.
- Check the connector of the BD detection PCB.
- Replace the laser scanner unit.
- Replace the DC controller PCB
Jun 30, 2008 | Canon imageCLASS D320 Digital Copier
Canon imageRUNNER 5570 Copier Logo
756 people viewed this question
old marine
old marine
