Question about Nikon D80 Digital Camera with 18-200mm Lens
Low Battery Indcator Flashes
I have had my Nikon D80 for 1 year. The last few times I have used the camera (even with the battery fully charged) the low battery indicator on the lcd screen will flash and it will not take a picture. If I turn the camera on and off or shake the camera the battery indicator will return to show a full battery. This is happening more and more often. Is there a problem with the camera or is it more than likely the battery going bad. thanks
    Scholar:
  • 48 Answers
You can check the status of your battery, including chargeble life remaining, in the Setup Menu. You need to have the CSM/Setup menu option to display Full menus, not Simple, in order to get battery status. So see if that battery status selection says you need to replace the battery.
Since you can shake the camera to get full battery, it's possible the battery contacts (on the battery or in the camera) are dirty, so check that.
If you do need a new battery, spend the few extra bucks to get a genuine Nikon EN-EL3e from a Nikon dealer. I have learned that many off-brand batteries do not properly implement a needed reserve, and "Genuine Nikon" batteries bought online from non-dealers are often counterfeit, just relabeled junk.
Posted on Mar 02, 2009
My nikon coolpix p530 wont turn on.
I take the SD card out and look at photos with my computer. If the battery is very dead it may not charge in the camera. Nikon cameras have a clock that runs when the camera is off. Fully charging it and leaving it alone for a year will most likely discharge the battery over 50%. If you have an external charger I would try that. When you charge in the camera you are right the power light come on and another light flashes. If you have an Electrical Engineer friend you could ask him/her to put a few volts on the battery to kick it back to life. A too deeply discharged battery may not charge in the camera
Jan 24, 2018 | Nikon Cameras
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
When I leave the fully charged battery in the camera for about 10 days it gets completely discharged. This is the original Nikon battery. I though the battery is old and bought a genuine Nikon battery. The...
Does your camera use a compact flash card? I've heard that some Nikon cameras have a problem with the flash card draining power when not in use. Try removing the card when not using and see if the battery lasts longer.
Apr 17, 2010 | Nikon D70s Digital Camera
FUji FinePix s1000fd, camera will not power on with new batteries, when it powers on it goes off in a few seconds or minutes indicating battery low, i have used fully charged batteries, ordinary batteries...
I have same problem as edmoze mentions above - batteries went dead. I first tried to use regular Duracell AA and it would still not come on. Went to internet & it recommended getting the Duracell rechargeable NiMh which I did. Got the charger & last nite they charged overnight. Today the camera did come on & I was able to download what I had taken. But what concerns me is that the low battery light is still flashing after a night of charging. What's up? Should I expect this kind of battery problem to continue? Seriously considering getting a Nikon Coolpix.
Sep 02, 2009 | Fuji FinePix S1000FD Digital Camera
Battery problem!
The camera has a design flaw.
Maybe HP can fix it with a firmware update but it's not likely.
I used an precision DC power supply to perform some electronics tests to find out what is going on with this model.
The issue is that AA NiMH batteries are rated at 1.2V DC each, and 2 AA"s in series add up to 2.4V.
Meanwhile the camera wants 2.7 volts DC or higher otherwise it gets the low battery error.
That is the flaw and we can't change that. It should continue to run at much lower voltage levels like other camera's and be able to use the full charge of the battery but it won't. So it runs the battery down from 100% down to about 98% and then it complains and stops.
Note that NiMH' batteries when fully charged are a bit above their rated value.. They actually have about 1.35V each so 2.7V total in this case. That's enough to start the camera but it doesn't last because in record mode the camera draws 450mA of current from the batteries (which is unusually high) and it quickly pulls the battery below the 2.7V level and the error comes up even though the batteries are still almost fully charged.
I measured 960mA of current draw when it's charging the flash which is a huge amount.
So this is just a really inefficient camera compounded by a low battery cutout circuit design flaw that is too sensitive.
We can't fix the design flaw but you could use higher voltage batteries. Granted,, this is not a great solution since you can't use NiMH rechargeables then but at least it gives you some options
Alkaline are rated at 1.5V each and even though they don't normally last very well compared to NiMH (due to higher internal resistance) they would last a while in this case. Perhaps 50-100 photo's or less if using the flash.
A better but more expensive solution is to use Lithium AA's. They have at least 1.6 Volts each and are very strong.
They are not rechargeable but you should get a lot of shots with a set of those, then look for a better camera.
Unfortunately this camera is far below average is pretty much every other category as well, such as high noise levels, low image sharpness, lack of any manual controls or dedicated control buttons for macro, focus, ISO, alternate screen modes to display useful info such as shutter speed or any other features that most camera's have by default. It has a 4 way rocker switch on the back but they didn't connect any functions to it.
It's also one of the slowest camera's made. Any Nikon or Canon would be a huge upgrade in features, quality, battery life, and photo quality. I have quite a few camera's and 20 years experience and can tell good features and those that are marginal. So lets just say that even though I only paid $39 (New) for this HP as a cheap spare it's going back to the store because it's just too lousy at everything. I can handle the 5Meg resolution which isn't a lot. I even have a 2Meg Nikon and a 4Meg Canon G3 from years ago that still take excellent, clear photo's. But this 5Meg HP can't even keep up with a 5 year old, 2 Meg camera.
Oct 12, 2008 | HP Photosmart M447 Digital Camera
Flashing Low Battery
Let me know if you have a solution...Mine just started doing the same thing
Dec 11, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D80 Digital Camera with 18-200mm Lens Logo
210 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
