Question about Nintendo Bottom Full replacement TFT LCD screen for DS Lite
No graphics on bottom screen but light working
Light comes on in bottom screen but no graphics appear
Have you tried replacing the battery? Once we replaced the battery in our ds lite the graphics and sound came back.
Posted on Apr 15, 2009
Wont Boot 1st PSU Flashing Amber
standard troubleshooting:
1) I've seen power sources appear to power up a system, but are somehow broken just enough to not get the system to POST (do you have another system you could at least borrow the power source from?)
2) pull anything you can so that you just have mobo, power, cpu, memory, and graphics.
2a) try using just one memory chip (and try each chip you have, or best to borrow a chip from a working system); even try different slots
2b) if onboard graphics, try a known working graphics card addon
2c) does the screen power off (like normal sleep) or system shutdown? if latter, try re-thermal pasting the heat sink to the cpu.
May 22, 2016 | Fujitsu Siemens Siemens PRIMERGY RX300...
The picture has began to flicker as though someone is shining a flash light on it, the picture is unsteady and a band has appeared at the bottom of the screen
Sounds like it's drunk
No really,..........think about it a minute............
Someone is shining a flashlight at it - Cop
The picture is unsteady - Drunk
A band has appeared at the bottom - Things a drunk sees
Sorry................you just have to have a warped mind like mine
Diagnose.......
1) Graphics chipset
2) Video Cable
3) screen Inverter -> IF USED
4) LCD Screen
I abhor posting generic one-size-fits-all information.
Post the laptop manufacturer name, and model number in a Comment.
This can be found on the Bottom of the laptop.
For example on a Compaq or HP laptop, there is a white Service tag on the bottom.
Product Number is what is needed. P/N = Product Number.
This way I can guide you step by step. It's confusing enough with exact information being given to you, much less pile a bunch of not needed info with it.
Diagnostic flowchart:
Graphics chipset. An external VGA monitor will be attached to the laptop, to check.
Video Cable:
Connections can come loose. Video Cable may have received damage.
screen Inverter:
A small circuit board mounted to the bottom of the Screen Frame, and behind the Display Bezel.
[The LCD screen is an assembly. It is composed of layers, and these layers are held in the factory set position; by a metal Screen Frame. Resembles a picture frame.
The plastic frame in front of the LCD screen, is the Display Bezel ]
LCD screen:
No explanation needed here.
This is the LAST component in the diagnosis. If everything ELSE is good, then this is replaced.
NOT replace LCD screen first!
Post back in a Comment.
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
Screen wont come on
I'd like you to start off by connecting an external display to your laptop, and see if a display (Graphics) shows on it. (The Display Toggle-Over key, and Fn may need to be used) From there we will know if the graphics chipset is good. Graphics chipset good, the problem is the Video Cable, or in the Display Assembly. (Display Assembly; essentially from the Display Cover to the Display Bezel. Includes LCD screen, screen Inverter, (If used and not LED backlighting), Wireless antenna, etc) Post back in a Comment with the Acer model number. This can be found on the Bottom of the laptop. I like to post concise information, and not a generic one size fits all solution. Regards, joecoolvette
Nov 09, 2012 | Acer Computers & Internet
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
When I turn on the computer this on the HD for fews seconds and then restart but never ever appear nothing on the screen.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 13, 2010 | HP Pavilion dv9000 Motherboard
Screen on laptop ...no signs of life
yes the graphics chip is bad its also made in to the motherboard we repair these every day the mother board are listed on ebay you can buy a whole working bottom for less then 70 bucks this is one of the few problem this model laptop seams to have.they are dependable normally. i have tons of parts for these laptops.
Dec 23, 2008 | Gateway M305CRV Notebook
Video card?
What graphics card are you running?
and what system do you have?
Nov 02, 2007 | Computers & Internet
Sapphire Radoen hd 2900xt m512 mb
Hi, Have you overclocked this card? if so inspect all the capacitors on it and see if any are leaking or bulging on top or bottom. If all appears well, then borrow another monitor and try that one. If that fails Check your RAM chips are seated properly.
If there is no change then the only answer is a faulty graphics card.
Regards mistyman
Oct 09, 2007 | Sapphire RADEON HD 2900XT (512 MB) Graphic...
Bottom Screen doesn't work but lights up
cable problem most likely usually cheaper to replace.
Oct 06, 2007 | Nintendo DS Lite Console
Nintendo Bottom Full replacement TFT LCD screen for DS Lite Logo
108 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
