Question about Cameras
Error 99 comes up on lcd screen prompts to turn camera on/off or reset battery. have done this . capture next photo then error 99 appears again
    Scholar:
  • 85 Answers
Replace the battery if its old
and cleanb the internal contacts of the connector where the battery connectes and then try.
Posted on Mar 01, 2009
  • 13,433 Answers
Can you first tell me the brand and model of your camera? thanks.
  • 10,594 Answers
Normally this error shows problem with lens assembly and I need to know exact model and brand of your camera to check its technical info.
Hi! i have a cannon ixus digital camera. It got wet about a year ago when i was at the beach, now the problem is every things okay except when i capture a photo nothing appears on the screen no image at...
Try and press the display button (on Ixus a square with a right pointing arrow) several times to see if your images appear at any time.
Your problem may be as simple as inadvertenly pressing this button into the off mode.
If that does not work, try to recharge your battery, reinsert it and turn the camera on again to test your LCD screen.
Since you haven't descibed any error codes coming up on your camera, I suppose it isn't that bad.
If this does not help you may have to get your camera repaired.
Good luck
Jun 28, 2011 | Cameras
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Error reading on screen on 1000e
Hello :
Here is what Canon said according some forums :
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Sony DSC T10 shows error E: 91: 01. Also flash
1. Turn OFF camera
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Your problem should be solved
Oct 31, 2009 | Sony Cameras
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
9. Take some pictures
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Camera is constantly buffering and virtually nonresponsive.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 11, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Canon rebel xs Battery and error 99 problems
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 1000D
Yep set the auto turn off higher and instead of removing the battery, just open and close the battery compartment.
This appears to be a problem I have raised with Canon, hopefully they will release a firmware update soon to fix this
May 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
HTC touch HD camera problem
If you done, all what is possible. Now try do next:
Push camera button and wait until camera frame will loaded. Dont release camera button. Now push hard reset key. And during restart keep camera button. Whan system will loaded, you can try use camera.
Mar 06, 2009 | HTC Touch HD Smartphone
Cameras Logo
15 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
