Question about Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System
99 chevy s10, fuel pump?
Drove fine in am, wouldn't start at lunch. All new from distrubuter to plugs, good spark. Fuel pressure reading 0, swapped fuel pump relay in fuse box with horn relay (same part number) horn still works. read about a fuel pump test wire under hood on the drivers side that could be jumped to battery to test fuel pump driver side but can't find it. similar models report relay being behind glove box but i don't see it there either. any more spcifics on this elusive test wire for this specific model? 99 chevy S10 ext. cab 4.3 L v-6? Any other easy ways to test fuel pump. also no codes showing on code reader. Read that oil pressure relay would take over pump relay with extended cranking, also did not work. truck will start breifly with starting fluid. No fuel pump can be heard with ignition being turned on (usually hear a 5-7 sec whine) all i hear now is a brief turning or valve sound similar to an automatic air freshener in a public resteroom. (2 brief spray sounds) but again no fuel pressure registers. That's about all the info I can give. please help!
  • Anonymous Apr 07, 2009
    Your wire plug to the fuel pump isn't getting a connection, so you are gonna have to unplug it and move it around a little bit then plug it back it and then you should here the fuel pump come on. You can reach the plug from under the truck but there is 2 plugs so make sure you do the right one.
This happened on mine and at first i had 4v at the harness going into the tank then it eventually went to 0v im prettysure thats why the pump burnt up but anyway after much head scrtaching i tied into the ground wire coming out of the tank and grounded it to the frame and the truck is running fine there vehicles are known for bad wire looms
Posted on Mar 07, 2011
    Sergeant:
  • 239 Answers
Have someone try starting the truck while you hit the bottom of the fuel tank with a hammer. if fuel pump is going bad the vehicle should start by doing this.
Posted on Mar 01, 2009
1995 Chevy S10 V6 4.3L 4x4 Pick up truck wont start
Make sure battery has a full charge. If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure and fuel injector pulse.
If you have tbi fuel injection, fuel pressure is 9--13 psi.
If you have cmfi fuel injection, my info says 55--61 psi.
Apr 24, 2017 | Cars & Trucks
I have a 96 Chevy s10 it cranks but won't start I
You need to find out if the fuel pump is working, getting gas up to the engine.
If the pump is working and seen to have good fuel pressure, check ignition by checking for spark.. To work, the engine needs, you know, gas, air, spark, and compression. Why people say, check for gas, check for spark.
Dec 20, 2012 | Cars & Trucks
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
Sep 05, 2011 | 1998 Ford F150 Regular Cab
Hi im working on a 92 volvo 740 with the 2.3 non turbo. the problem is i just did a motor swap the old one had "hard knocking " drove car in ran fine but loud. did the swap- while it was on the...
NEED ADJUST SET IGNITION TIMING.MOST TIME YOU INSTALL ANOTHER NEW ENGINE.THE IGNITION TIMING AT DISTRIBUTOR OFF TIME LITTLE TOO FAR ADVANCE CAUSING WEAK SPARKS FOULING OUT SPARK PLUGS. CHECK FUEL PRESSURE SOON AS ENGINE STOP AGAIN DONT TURN ON IGNITION SWITCH CHECK FUEL PRESSURE.SHOULD BE 43 PSI. IF NOT 0 FUEL PUMP BAD OR FUEL PUMP RELAY FAULTY OR FUEL FILTER STOPPED UP.IF FUEL SYSTEM GOOD PROBLEM IN THE IGNITION TIMING.
Mar 11, 2011 | 1992 Volvo 740
I have a 1998 chevy s10 with 195000 miles, drove home from work last night went out this morning started right up died out 45 seconds later, now wont start, battery is fine,and fuel pump is still making...
98 chev pickup s10 put gas in the gas tank drove it about 2days and the check engen light came on had it check mech said it was the gas cap replace the gas cap the light back on now what help
Dec 02, 2010 | 1998 Chevrolet S-10 Pickup
My 2000 chevy S10 wont start I changed the battery and it ran fine for 2 days now it will turn over but won't start
Check Fuel Pressure. First turn key to on position (without starting) and listen for the fuel pump motor. If no motor sound, your fuel pump is not working. Check fuel pump fuse and relay. If fuel pump works, check for pressure at the fuel rail (schrader valve on fuel rail for pressure testing). If no pressure, or not enough, fuel filter might be clogged or fuel pressure regulator may not be working properly. IF fuel is not the problem, start checking electrical, such as ignition control and proper spark to plugs.
Aug 14, 2010 | 2000 Chevrolet S-10
Isuzu Hombre pickup, 2.2L Vortec, Won't Start.
You need four things for an engine to run. 1. fuel 2. spark 3. compression 4. timing (spark at the right time. By your post it seems you have fuel and spark and you probably have compression unless you blew a head gasket. That leaves the timing. Check the timing and/or the timing belt or chain whichever you have.
Jul 01, 2009 | 1998 Isuzu Hombre
Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System Logo
2,191 people viewed this question
Top Minuteman Computers & Internet Experts
David Payne
David Payne
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
