Question about Water Heaters
Overheating hello, I have got baxi solo 3 pfl 30/80 gas boiler.Very often even a few times a day overheating appear in my boiler when reset the knob it is fine for a while and then it comes again the pump got very hot and rads get very hot even thought the temperature control knob is turned down .Pump seems to work at least when I touch it, I can feel  vibration.
  • 30 Answers
You could have a flow problem due to sludge or scale in the boiler, it could be a pump problem as it may not be circulating enough water around the system. or it could be a faulty thermostat if it is not cutting out soon enough.
1st try turning the boiler stat down to its minimum, if it still over heats then it is probably the stat.
if you have a switch on your pump to increase the speed make sure it is on setting 3. if the pump is old then it may be time for a replacement.
Posted on Mar 30, 2009
Prestige 110 boiler won't ignite
Is there gas cause most of the time it won't ignite cause there is no gas. What you can do is light it your self and if it lights that is good and if it stays light than there is has sometime you have to light it your self
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Problem with IGNITION LOCKOUT
Air in the system or low gas pressure?
Apr 25, 2013 | Water Heaters
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
Jan 22, 2013 | Water Heaters
BAXI E130 ERROR CODE AND SHUTDOWN
overheat stat or fan check very small hose at fan area for pinhole
Oct 02, 2009 | Water Heaters
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Manual for Baxi Boiler
any merchant will get one mailed out to you
Jan 24, 2009 | Water Heaters
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Water Heaters Logo
446 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
