Question about Dell Dimension 4500 PC Desktop
Add wireless card
I have wireless for my laptop at home---and would like to add wireless card to my desk top.  My desktop is a Dell Dimension 4500.  Can I add a wireless card to that model?  Is there a universal wireless card or do I need to use a particular one?
  • 4,889 Answers
You can install and Desktop wireless card. Some good brands are Belkin, Linksys. I personally use a Belkin G desktop wireless card and its pretty good. You can get it for around 25$.
Hope that helps,
Sai.
Posted on Mar 01, 2009
    Guru:
  • 1,342 Answers
You can add one via a USB port like THESE
Or you can add one to an empty PCI slot on your motherboard if you have one available. Like This One
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
Can i put an ethernet port into my Dell Dimension 4500s tower?
Of course, just add a PCI LAN card of a small profile. One like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=534927&CatId=587
If necessary remove the front blade - 2 screws to take out.
Aug 06, 2011 | Dell Dimension 4500 PC Desktop
How do I connect my dell 4500 to an ethernet connection? My desktop does not seem to have a connection port. My DSL company (AT&T) sent me a new modem motorola MSTATEA and it does not have a telepohne...
The Dell 4500 uses an add-on PCI card for ethernet.
You may not have ordered this PC with one.
You can purchase a card for this system, if you are comfortable with installing additional cards into the system. The system is
Here is the link from Dell on installing cards. http://support.dell.com/support/edocs/systems/dim4500/replace.htm#1138309
Amazon sells these cards: http://www.amazon.com/s?ie=UTF8&x=0&ref_=nb_sb_noss&y=0&field-keywords=PCI%20network%20card&url=search-alias%3Daps
Jun 15, 2010 | Dell Dimension 4500 PC Desktop
I networked my desk top vista with my dell, my dell can reconize the connection but can't pick up the internet
Did you put in youe network password, if you are running wireless you have to input the same password as the other machines and wireless devices. If your running wired go into your network and click on properties you may just have to physically add it to the network, use the connection wizard if you arent sure it's in the network properties menu, just click on "add a new connection" and follow the prompts, i can only assume so much without more info. You may have a router issue, but try this first
May 19, 2010 | Dell Dimension E310 PC Desktop
I have been using a dell inspiron but its gone
Dell Studio XPS will have the high end gaming capability you want, and a fairly reasonable price.
http://configure.us.dell.com/dellstore/config.aspx?oc=dxcwnn1&c=us&l=en&s=dhs&cs=19&kc=studio-xps-8100
Yes, you can add Wireless to a desktop, on that link there is an option for a Dell Wireless 1525 card for $40, or you can add one later either PCI or U
May 06, 2010 | Dell Inspiron 1501 Notebook
I have a wireless card in my Dell Dimension
The first thing I would try would be to reset the card, by removing the cover (if you are comfortable), removing the card from the slot and reinserting in the slot or moving the card to another slot (if there is an identical slot). If that doesn't work, replace the wireless card either with another wireless card or a USB wireless network adapter (external adapter that connects to a USB port). Good luck.
Jun 15, 2009 | Dell Dimension 4500 PC Desktop
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
I have an older Dell dimension 1100 desk top and want to add a pc
Sure, if you are using XP, you should have no problem installing a second video card.
Here is a link to a dual head video card if you need it... http://www.newegg.com/Product/Product.aspx?Item=N82E16814133233
Hope this helps, if so please rate my solution accordingly. Thanks, David
Mar 19, 2009 | Dell Dimension 1100 PC Desktop
Can I access the internet wirelessly with a desktop pc?
Theoretically, yes. you'll just need to install the correct driver on the dell and know what you're doing when you install the wifi card.
Mar 08, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Dimension 4500 PC Desktop Logo
222 people viewed this question
Alun Cox
