Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freezer compartment temperature stays above set point
Model GC3SHEXNS16
serial SU 3627342
  • 27 Answers
Rotate the cooing nob to maximum
Posted on Mar 10, 2009
Model 106.44109300. What should the temperature controls read for the refrigerator and freezer?
Valerie,
Set point for the freezer should be between -5 degrees and 5 degrees above 0. Set point for the refrigerator should be 33 degrees to 41 degrees. Hope this helps! If you need a copy of the owner's manual, you can find it here.
10644109300 KENMORE REFRIGERATOR Manual
Aug 04, 2015 | Kenmore Refrigerators
The temperature for the fridge and freezer will not stay constant. Why?
I would think first of the defrost termination thermostat malfunctioning.
This would vary the defrost time since it regulates the defrost time by temperature.
This is the most common failure in fridges next to start relays.
It is a two wire item in the freezer section which is clipped onto a tube. It senses
line temperature and turns off the defrost element when that temp is reached.
Should be located in the freezer section behind the back panel. Model and serial
number should be inside the refrigerator compartment, Part should be available
at an appliance parts store. Hope this helps.
Jul 18, 2011 | Kenmore Side by Side Refrigerator
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
My GE Refrigerator model GSL25JTFBBS stay in
Good day,
35 minutes would be considered nominal. That is the amount of time needed to heat up the cooling coils behind the rear panel in the freezer compartment, and then allow it to drain the condensate water out the drain.
The defrost cycle is made up of 2 parts.
The first part involves shutting all fans and compressor off, and turning on the heater/heaters mounted on the bottom of the cooling coil to above freezing. About 10 to 15 minutes.
The second half occures when a defrost thermostat mounted on the top of that coil senses the coil is above freezing. It cuts the power to the heaters, and lets the system just idle, while the water is allowed to drain out of the drain.
If that tstat is working properly, the food temperature is affected slightly but never to an above freezing condition.
The thermostat is a small 1" round disk clipped to the top of the coil.
Only one possibility, but that tstat could be hanging allowing the freezer coil compartment to reach a very high temperature. If so, it needs replaced.
You should also check to see if both fans and compressor start running as soon as the cycle is done.
Mar 12, 2010 | GE CleanSteel GSL25JFTBS
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Only one temperature control??
Good day,
Yes, they are made. The temperature in the fresh compartment will be no issue, since you have control in that compartment.
The engineers designed the balance between the two compartments so the freezer would be normal if the following conditions applied.
1. The room temperature is between 70 and 90 degrees.
2. The machine has normal usage. I.E. 8 to 20 door openings of the fresh food door.
The freezer would start getting warmer if the room temperature dropped much below 70 degrees. or..
If the machine had extremely light usage with very few
door openings, or a combination of both situations described above.
With dual controls, and both set at normal, the above conditions would occur anyway, except you could over ride the normal settings to compensate.
Many people have this setup, and experience little trouble, but without knowing your life style replacing it would be your choice based on the facts given.
Thanks for using FixYa
Dec 23, 2009 | Refrigerators
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Dec 02, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
