Question about Refrigerators
Fridge either on or off, no cool
Temp control at 1 and it doesn't cool; at 2 it freezes up;
  • Anonymous Mar 03, 2009
    It's about 8 years old.
  • Ken Bledsoe May 11, 2010
    Really sounds like your temp. control isn't working properly. Need new one. Is your unit around 10 years old or so?
  • 400 Answers
Your thermostat (temp control) needs to be replaced.
Posted on Mar 05, 2009
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
My fridge keeps beeping even though the door is shut. The fridge temperature indicator keeps going up and then down. Can you please tell me what's wrong?
Is the beeping a door or temp alarm? You can press power cool and power freeze buttons at the same time and you should get a single LED indication and then after 30 seconds the
display should return to normal. NOTE the position of that single LED should you see it.
1) Self-Diagnostics in the initial Power ON
1-1)The control board performs a self diagnostics test within 1 second and check out the temperature sensors abilities.
1-2) If a sensor failure occurs, a corresponding LED segment will blink with a beep.
1-3) When a LED segment blinks, only the cancellation function (Press Power Freeze and Power Cool buttons
simultaneously for 8 seconds) is acceptable.
1-4) After a replacement of bad sensor or a cancellation of this function, this self diagnostics will end.
2) Self-Diagnostics in the normal operation
2-1) To select this function, press Power Freeze and Power Cool buttons simultaneously for 8 seconds with an audible tone.
2-2) In the self diagnostic mode, only corresponding LED segments will be illuminated (see the check list on the next page) <NOT in this post Interpreting LED position = these errors below. You will need to pass on / reply with exact position of the LED that you see
1 ICE MAKER SENSOR
2 REFRIGERATOR SENSOR
3 REFRIGERATOR DEFROST SENSOR
4 REFRIGERATOR FAN ERROR
5 ICE MAKER function error
6 CoolSelect ZoneTM SENSOR
7 REFRIGERATOR DEFROST ERROR
8 EXIT-SENSOR
9 FREEZER SENSOR
10 FREEZER DEFROST ERROR
11 FREEZER FAN ERROR
12 CONDENSER FAN ERROR
13 FREEZER DEFROST ERROR
2-3) After a 30 second illumination of error signal, the system will return to the normal operation.
I suspect a thermistor problem.
The unit will self diagnose if you unplug it for 15 to 20 minutes and then plug it back in. ANY errors will be displayed by a single LED (digit) indication during the first 14 seconds after you plug in the unit.
You must wait that 15 - 20 minutes of unplugged time to prevent the compressor overload from tripping due to high coolant pressures. System must stabilize first to prevent damage to your unit.
Thanks for choosing FixYa,
Kelly
Nov 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
My fridge keeps freezing how do i change the temp settings
Hi!!
You didn't mentioned brand and model of your fridge, so I will give you a general answer.
Usually the controls are in the fridge compartment, either on the right or back upper wall. Usually is one control for the freezer and another for the fridge. The normal settings should be about 1/3 of the dial's range, ie. If dial have 9 numbers, the setting should be between 3 and 4, depending on use and outside temp.
Wait 24 hrs. between adjustments to allow the system to stabilize.
.NOTE:
The Freezer Temp. Dial is the main temp. controller, if you set it too low, it may not have time to cool fridge side properly.
Good Luck!! Don't forget to rate this post!!!
Aug 03, 2010 | Refrigerators
Refrigerator 1/2 temp will not get warmer than 28 degrees
try and replace the thermastat control.
turn both knobs to the off position and listen i the fridge for the cold air damper to close it is located top left side rear of the cabinet in the fridge if the door does not close then you may need to replace the damper
Apr 13, 2010 | Frigidaire FRS26R4A Side by Side...
We have a side by side and the refrigerator side is freezing everything. we have the settings on 2 and D
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 16, 2009 | GE GSS20DBT 19.9 Cu. Ft. Side-By-Side...
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
My fridge stays on and freezes everything inside
not a breathing room issue, if anything that would cause it to shut down and not cool at all, where you got just the opposite, it never shuts off. is it an electronic model, or is there a control knob you manullay turn to adjust temp
Feb 23, 2008 | Sanyo SR-4910M Compact Refrigerator
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
