Question about Brother HL-2040 Laser Printer
Have replaced drum but when it has printed it's light and grainey
  • 523 Answers
Check the devloper unit if it has, if not it will be the fuser.
Posted on Mar 01, 2009
We have a Brother HL 2140 series the printer will not print. It has a new toner cart. The drum light is lit . Any suggestions?
This machine has a separate drum and toner cartridge. Replacing the toner does not reset the drum light. Double check that the light on is, in fact, the drum light, and if it is, replace the drum unit. This should resolve your problem.
In order to replace the drum unit, do this: 1) With the printer on and the drum light blinking, open the front cover. 2) Press and hold the Go button for about 4 seconds until all the LEDs light up. Once all LEDs light up, release the Go button. 3) Pull the print assembly out of the machine. 4) Push down the green lock lever to take the toner cartridge out of the drum unit. 5) Put the toner cartridge into the new drum unit. 6) Reinsert the print assembly into the machine. 7) Close the front cover and verify that the lights turn off.
It is theoretically possible that you could reset the counter without actually changing the drum by simply skipping steps 3-6 above, but I have never tried it before and Brother may be checking a chip on the drum unit to verify that it is, in fact, a new drum unit. If they are, you will have to actually replace the unit to make the light go off. I would strongly recommend against resetting the counter without actually changing the drum though, as your print quality will degrade and the machine may start to dump toner into the inside creating a rather large mess and a hefty repair bill.
Feb 28, 2011 | Office Equipment & Supplies
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Jun 23, 2010 | Dell 1720dn Laser Printer
Drum light flashing
We have just changed our drum unit but the drum light is still flashing. The printer is printing though. Any suggestions?
Apr 12, 2010 | Brother HL-2150N Laser Printer
Drum light blinking
The light blinking means it's almost used up, when it comes on solid it will stop printing. If your prints still look good you can open the front door and hold the go button til all lights flash, and it will think it's a new drum. You can replace then when print quality gets bad.
Jan 06, 2010 | Brother HL-2040 Laser Printer
Drum unit light showing and not printing
Try cleaning Drum or replace Drum,that's why the Drum light comes on
Sep 04, 2009 | Office Equipment & Supplies
Only when I print photos I get grainey lines I went through the cleaning process several times even called epson to troubleshoot no luck
Check nozzle? All lines appear? vertical line for each ink is straight? Another ink droped outside lines?
Jun 28, 2009 | Epson Office Equipment & Supplies
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
AL-1631 Repalced drum, but light is still on
If you will replaced the drum you should reset the drum counter .
To reset follow these steps:
Step1: Press continuously Clear key then press Exposure key then Clear key then Exposure key
Step2: You are inside the simulation if the display turns off but if not do again step1
Step 3: Press 24 then press print button then press 7 then press print button
If not canceled try step4
Step4: Do step1 to step2 then Press 24 then press print button then press 6 then press print button
Mar 03, 2009 | Sharp AL 1631 Copier
Sharp AL 1010
Hi, to reset drum light follow this sequence: press cancel, exposure, cancel, exposure. Display goes blank, enter 24, print, 07 print, cancel cancel. Cheers
Andy
Jan 25, 2008 | Sharp AL 1215 Black and White Copier
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
