Question about Kenmore Washing Machines
I have a Kenmore Elite HE3T front load washer. I am getting the F 02 error. I checked the drain hose I do not detect any bloggage or kinked hose.
  • dmehr May 14, 2009
    during wash cycle the washing machine starts beeping and giving the f 02 display
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
F02 error on Elite HE3t washer even after cleaning. Loud Clicking noise coming from pump. What do I need to Do?
F02 means Long Drain Error or Drain time longer than 8 minutes.
SUDS is typically a secondary error.
This is indicative of a drain pump problem and/or clog in the drain line.
You should check the following:
To check the drain pump, click HERE for step-by-step instructions.
Thanks
Oct 05, 2011 | Kenmore Elite 45986 Front Load Washer
I have the kennmore elite he3t. Error code f 02 and it will not drain Is there a solution to this problem you know of?
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Jan 03, 2011 | Kenmore Elite 45986 Front Load Washer
With Kenmore Elite front load washer, what is F02 error?
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore HE3t is flashing F02 and wont spin...what can I do.
Hi
Thanks
Rylee
Jul 19, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite error message F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite he3t front loading washer and the washer will not spin or drain and shows an f2 code. any suggestions
May 04, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer he3t- beeping F02
"F/02"
Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Feb 13, 2010 | Kenmore Washing Machines
Getting an 02 F flash
F02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Aug 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite washer drain problem
Mar 23, 2009 | Kenmore Elite 45986 Front Load Washer
F02 error
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
60 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
