Jeep 1992 YJ Door handle did not work, someone else took it apart and I am trying to fix it and put it back together, however I do not know where the pieces go. I am trying to find a diagram of this so I can fix the door
Ok, the inside panel is cardboard with faux leather. remove the screws holding on the inside handle and the frame of the doorlatch.
there is a plastic joint that connects the two rods that actuate and open the door. the rods are bent at the end to slip into the white plastic joint. this design is stupid and often times that joint can break, or the rods fall out. solution is to reattach them together and wrap mechanics wire or bend the very ends of the rods so they wont come out.
its something i cant really explain, but the design is straight forward. also, keep track of the threads on the rod that connects to the claw that meets the striker on the frame of the jeep. if for any reason its not adjusted properly, it will not latch properly.
My door will not open from the inside or outside. At first, it did not open from the inside. Now the door does not open all together. I have tried several times to take the door apart but I have not been successful. Does anyone know how to fix it?
