Question about Dell Inspiron 1200 PC Notebook
How do you reset cmos bios administrator password
How do you reset the admin. password i cant even get into bios setup? i pulled all batteries and cmos battery for 5 hours with no luck!
Open case and look for jumper info in case read the info and reset the jumper
Rick
Posted on Mar 01, 2009
How can i reset the bios power-on password for hp 6720s ?
Do you want to know about bios power-on password reset on HP 6720s?
Turn to Reset HP BIOS/Administrator Password
It shows you how to reset HP BIOS password with SpareKey, and how to reset HP administrator password with effective Windows Password Genius in just 2 minutes.
Get a video learn how to use it:
http://www.youtube.com/watch?v=-vrVcFaUATg&feature=youtu.be
Mar 05, 2011 | HP Compaq 6720s PC Notebook
Dell Latitude D620 BIOS password help!!! I bought a Dell D620 and I noticed that some BIOS features are password protected. The previous owner said he doesn't know anything about it, so I'm not sure what...
Dell usually sets a default password as password or admin Try those first. If no luck go into the bios setup by continually tapping the exc key while the computer boots. If your licky you may be able to set yourself as administrator and give yourself admin rights. With admin rights you can do anything.
Nov 11, 2010 | Dell Computers & Internet
I forget bios setup password and iwant to know how broken bois hdd password
reset the the bios..disconnect all the input mains power supply..pick open the cmos battery..replace/resit it in again..
this'll hopefully break open bios/cmos password..
to enter in windows..after boot in shell/dos mode n before in windows/gui mode or before the Welcome Screen appears, press Ctrl+Alt+Del..classic logon will open..here in the User Name type: Administrator..press OK or hit Enter..u'll b logged in..
hv professional supervision of ur system admin or vendor....
Nov 05, 2009 | Computers & Internet
I have asus mother board support to core 2 duo and quad core recently purchased and inserted quad core processor. Problem is forgot my password. How to avoid that trouble myself
what kind of password? bios or administrator password should be clear!..
if bios password reset it.. else administrator use PROGRAME OR SOFTWARE TO REMOVE IT.. LIKE < password changer which can dowload from the internet... try it..
Sep 12, 2009 | ASUS PC-DL Deluxe Motherboard
Hp compaq nx8220 - Administrator password cannot be reset
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
Jul 28, 2009 | HP Computers & Internet
D520 setup locked, cannot change boot order or re-install os
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Jul 24, 2009 | Dell Latitude D510 Notebook
Bios password
try removing the cmos battery. power in on without the battery.
Jul 07, 2009 | IBM ThinkPad T21 Notebook
I lost my admin password for bios setup
You can clear the bios password by removing the CMOS battery from the motherboard, make sure the PC is disconnected from any other power source, wait a good 3 - 5 minutes, hit the power button a few times to make sure all power is drained from the capacitors, and then replace the CMOS battery. You can then power on the PC and the bios password will be removed.
Jun 25, 2009 | IBM ThinkPad X61 Tablet PC
Admin password
Are you refering to the BIOS possword? If so, you can try and reset the jumper for CMOS on the motherboard of you machine. It should next to the CMOS Battery.
Mar 04, 2009 | Dell OptiPlex GX620 PC Desktop
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
Dell Inspiron 1200 PC Notebook Logo
213 people viewed this question
Alun Cox
