Question about Canon PIXMA iP1800 InkJet Photo Printer
How do you insert the ink car
I have a canon printer IP 1800 and I cannot get the ink cartridge inserted...pls help
    Sniper:
  • 55 Answers
Here is the picture user guide for inserting the ink cartridge
http://gdlp01.c-wss.com/gds/6/0900005936/01/ip1880_esi_as_v1.pdf
Hope it helps
Posted on Mar 02, 2009
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
How do I insert my ink cartridge into my Canon MP240
1st you must switch on the power. the lift up the scanner unit. The you will see the cartridge holder moving to the left hand side. And then you may insert the ink cartridges.
May 21, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Ip1300 does not recoganise the inks
cleane the bouth the cartridge head then try other wise change the cartridge
Oct 03, 2009 | Canon PIXMA iP1300 Printer
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Encountered problem inserting cartridges
Hi. Go to this site:
Pixma iP1600 Support
On the Support and Service tab there is a Search Our Knowledge Base block.
Below "Please enter your question:" type in "replace ink cartridge". (Without the quotes of course.)
Click on "Search". One of the choices that appears is "How do I install the ink cartridge(s)?"
Click on it and a window will open with pictures and animations to guide you through the process.
Thanks for using Fixya.
A "Fixya" rating would be most appreciated.
Jan 26, 2009 | Canon PIXMA iP1600 Printer
Canon ip 1800 refilled ink says ink has run out, it's full
Here's how to reset the printer so it doesn't give you the out-of-ink message:   1)  Hold down the flashing yellow RESUME button for almost 1 minute 2) Open the cover 3) Release the cartridge(s) (#30 is black, #31 is color), and then reinstall cartridge(s).  Close cover. 4) Turn printer OFF (I had to wait and try this numerous times as green light was flashing & it wouldn't shut off.  Wait, then press OFF again. ) 5) Turn printer back ON, and cheer when it prints.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
I cant put the fine cartridges ip 1800
Go to this link and type "install ink" in the Search box. Click on the Search button, then click on the link "How do I install cartridge(s)?". You will get an illustrated and animated guide. Please note in step 1 that you must turn your printer on and allow the cartridge carrier to move all the way to the left before inserting the cartridges.
Mar 07, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
64 people viewed this question
old marine
old marine
