Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Western Digital MY BOOK 500gig - Drive does not appear
My m8 has just got me this drive. he loaded it up with stuff on his pc but now when i plug it inot my lap top the drive does not appear in my computer. Dispite it installing itself and saying "your hardware is installed and ready to use" It also seems to show up in the device manager as USB mass storage device and appears to be working properly. However still does not appear in my computer. Ive tried various usb ports, rebooting, etc> Help would be appreciated. Thanks Dino Well I bought My Book essential edition of 1tb and I have the same problem of you guys. The disk doesnt appear in My computer. I've contacted wd and they told me to change it if its still in warranty. Any ideas?
  • Chuck May 11, 2010
    when you unplug this unit do you unplug it after disconnecting it first? or did you unplug when computer was off? if you unplugged while pc was still running without shutting off using the usb disconnect at bottom taskbar then you couldve messed up the configuration. i actually had the same one and the only thing that would help was to reformat it which defeats the whole purpose of having a backup drive. they replaced mine too. No problems since then. that was 2 years ago.
  • 702 Answers
Check the driver letter assignement, and make sure there is no conflict on that (happened to me on my laptop as well).
I found out by reading this: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Definitely don't format if not required, you can first try to restore the MBR.
Posted on Mar 02, 2009
Got wd elements 1.5 tb plug n play hard drive n errh it wont plug n play ??? used on playstation 3 always worked used on my lap top and other peoples neva had any problems lent to a m8 he removed with out...
PlayStation 3 has a Unix like operating system. It is proprietary. http://www.tomshardware.com/forum/279261-32-retrieving-files-stuck-help
The below is how the WD was reformatted to accept P3 content. Even if the PC reads the Fat format, the file types are native to the Unix like system, not Windows. But the above link may be of some help.
http://www.wikihow.com/Add-an-External-Hard-Drive-to-a-PlayStation-3
Jun 14, 2017 | Western Digital MY BOOK HOME 1TB EXT...
Multiple Western Digital My Book 1 Tb not registering
The naming wouldn't affect the drives appearing. Sometimes, the drive letters can become a problem (from experience). This happens when both drives try to occupy the same letter. Open disk management and check to see if both drives are visible at the top. If so, manually, right click on one of them and select "change drive letter and path". Select something, you know isn't normally occupied.
Jan 05, 2010 | Western Digital My Book Essential Edition...
You can go to Adminisstrative tools/computer managment/disc managment and chance letter na partition. it will fix the problem
Oct 31, 2008 | Computers & Internet
Western Digital My Book Pro - Replace Disks
Same problem. This from WD Answer ID 1664:
Important: The user serviceable enclosure will only work with replacement hard drives from Western Digital. Inserting a non-Western Digital hard drive into the enclosure could cause damage or data loss.
So Hitachi drives will not work at all. After talking to tech support, it seems you have to have them send you a replacement disk in order for it to work.
I'm looking for a way around this since I want to upgrade my dual 500 G drives with dual 1 TB drives also. Maybe they throw something onto the boot sector that tells the MyBook controller what to do, who knows? The search goes on.
db
Oct 24, 2008 | Western Digital My Book Essential Edition...
Western Digital 500gig External Harddrive. Power up troubles.
this is a bit tricky , you'll need to tell my what operating system you have ,
more than likely sounds like windows power management is turning the drive off
check your power management settings.
if thats not the case just let me know.
shalom
Aug 20, 2008 | Western Digital 500GB My Book World...
Western Digital 500gig external drive
it sounds like hard drive data may be corrupted. This could be due to a number of things. A power failure, hardware failure etc.. If the drive will not even let you access it you'll probably have to just format it im afraid.
- John
Jun 23, 2008 | Western Digital 500GB My Book World...
Error code -1309
Try to copy the file to another part within the drive it's in, this is a READ error. once it's there, move it to the WD drive.
Dec 10, 2007 | Western Digital My Book Essential Edition...
If it is showing up in your device manager - is it also showing up in the disk manager? If it is you can check if it has a letter name attached or if you need to give it one.
Oct 02, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
517 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
