Question about Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch
How to change time and date on a screen? - Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch
  • olegshubayev Mar 03, 2009
    I did it, but it's changing views of the sceen, not the time. And I also lost my manual.
    Thank you for your help.
  • pbeck May 11, 2010
    Are you trying to change the date and time on your wireless router?
  • 40 Answers
Push the right key (>) or the left key (<) to cycle
through the display modes.
Pages 18-21 of the user manual
Posted on Mar 02, 2009
  • pbeck Mar 03, 2009
    Ah, sorry I miss understood.
    The manual for your Belkin is available here:
    http://www.belkin.com/support/product/?l...
    Page 84
    The N1 Vision keeps time by connecting to a Simple Network Time
    Protocol (SNTP) server. This allows the N1 Vision to synchronize the
    system clock to the global Internet. The synchronized clock in the N1
    Vision is used to record the security log and control client filtering.
    Select the time zone that you reside in. You have the option to select
    a primary and a backup NTP server to keep your N1 Vision’s clock
    synchronized. Select your desired NPT server from the drop-down
    box, or simply keep it as is.
    If you reside in an area that observes daylight saving, then place a
    check mark in the box next to “Enable Daylight Saving”. The system
    clock may not update immediately. Allow at least 15 minutes for
    the N1 Vision to contact the time servers on the Internet and get a
    response. You cannot set the clock yourself.
    Cheers
How do i change the time
For Windows 10 following these steps to change the time and date:
1. Right click on the time (Normally at the bottom right-most corner of your screen, on your start bar)
2. Select Adjust date/time
3. Press Change (Button under Change date and time text)
4. Set the time/date, and press Change
You can also change your timezone, daylight savings and automatic internet vs manual time on that setting page.
Nov 08, 2017 | The Computers & Internet
Date change
Click on time section of your start bar (bottom right of screen). Then choose adjust time and date settings.. Following on screen setups to change it over to correct date and time..
Jan 06, 2014 | Acer Computers & Internet
Always has to fix date and time
1. Double click on time (right hand corner of your screen).
2. Change date and time (xp)
3. Click on change date and time (windows vista,7,8)
Dec 17, 2013 | Computers & Internet
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
Jun 10, 2013 | HP Compaq Presario V2000 Notebook
How to change the time
You can find the full manual here:
http://www.obfs.uillinois.edu/common/pages/DisplayFile.aspx?itemId=918000
But here's the part about changing the time:
System Reset-DATE or TIME
To change the terminal Date and/or Time:
1. Press the More function key.
2. Press the green Enter button until the terminal screen displays Other Set Up.
3. Enter the password (last six digits of the Merchant ID# or 998877).
4. Press the Enter button.
5. Press the More function key.
6. Press Enter until the terminal screen displays Date/Time.
7. Press Enter for Date (MMDDYYYY), enter the correct Date, and press Enter. Go directly to Time, and bypass Date, by pressing Enter twice.
8. Press Enter for Time (HHMMSS), enter the correct Time, and press Enter.
9. To Exit, select the red Cancel/Clear button twice.
Mar 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
The time and date are programmed through system programming. A 4015 phone cannot do this programming. A 4150 phone setup as a subattendant phone with the "attendant setup time/date" class of service option enabled for the 4150's class of service can change the system time and date. This is accessed through the LCD touch screen keys of the 4150. Scroll through the options in the screen until you find set time /date.
Also an attendant console with the "attendant setup time/date" class of service option enabled for its class of service can change the time and date. Press the function button then choose attendant function.
Choose set time. Enter the time in four digits as in 0800 for 8:00. Choose PM if needed. Choose set.
Choose exit to finish.
Dec 13, 2010 | Mitel Superset 4015 Corded Phone
How do i set the clock? l have clicked on clock and tried entering numbers but nothing happens
Enter into BIOS
  • Enter the CMOS setup.
  • system setup screen see the date and time
  • Using your arow key on the keyboard navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow key / your page up / page down keys to change the date.
Using Msdos command
  • Press Control + r key togather
  • type cmd
  • on the black screen type date
  • press enter. It will be showing the current date and also asking you to put the new date in the format mm-dd-yy,
  • type new one as per format
  • press enter
For time
type cmd
on the black screen type time
press enter. It will be asking for new time,enter new time and close the black box.
GOOD LUCK!!
Sep 24, 2010 | Computers & Internet
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PowerShot A480 Digital Camera
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Cant change time on phone
time & date
Your phone needs the time and date for the datebook.
To synchronize the time and date with the network:
Press - > Settings > Initial Setup > Time and Date > Autoupdate
> On
To set the time and date: Press - > Settings > Initial Setup
> Time and Date > time or date.
To choose an analog or digital clock for your home screen,
press - > Settings > Personalize > Home Screen > Clock > Analog or
Digital.
hope this helps
riz.
Nov 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch Logo
649 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
