Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
White flickering box shapes made of lines
I have an Westinghouse LTV-32w1 that has developed white flicker shaped boxes made of lines about 1/3 of the way down from the top of the screen equally spaced across the screen. This is from my cable box that is hooked to the Component 1 port. If I put in a DVD the boxes go away and I get white flicker lines at the bottom of the screen. It is hooked to the Component 2 port. Other than this problem the TV is working great. What I am trying to determine is this a problem that is being caused by the main controller board or the LCD controller board that is part of the LCD display. I know how to replace these boards no problem. I just need to know which on to replace. Any suggestion or help would be appreciated.
  • 1 more comment
  • Joseph Hegwood Mar 01, 2009
    I have tryed all of the inputs and I get some form of the same problems listed above. The problem does not go away by swtiching inputs. I know there is something wrong with the TV I am just trying to determine which board I need to replace based on the problem I am having. I think I need to replaced the main board but I am not sure. It could possibly be the LCD controller board. I need someone to point me in the right direction.
    I will order part and replace to see if this fixes the problem. I will update you after I have done this.
  • Joseph Hegwood Mar 07, 2009
    Replaced the LCD Controller board and the problem is exactly the same as before. Will try the main controller board next.
  • 6,784 Answers
Hi, this seems to be an isolated problem that is located on the input block side of the logic circuit board. these two input blocks may have become unstable, due to poor solder contact points. this is a job for a qualified tech that has experience with soldering and iron handling. a point break test will also be needed for preventive maintenance while the Tv is disassembled.
Posted on Mar 01, 2009
    Scholar:
  • 165 Answers
U need to replace the lcd controller board.
    Brigadier General:
  • 8,619 Answers
Hi!
Try using HDMI cable or try using the tv on a diffrent AV mode.
  • Rylee Smith
    Rylee Smith Mar 01, 2009
    You need to get your X-Board(X-sus) repaired or repaced. As these type of bars/boxes occur when either the x-board connector is loose or drive IC on the x-board is faulty.
    Thanks
    Rylee
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Lights filicker on and off. Weather the fan is on or not. All wiring is good.
for the lights, open up, remove watt governor then rewire. should take care of flickering. but turn power off first ! after removing. hook white wire to white wire and black wire to red wire, this is the power or hot wire. it is a black box shape.
Apr 02, 2012 | Hampton Bay 52 In.Carriage House II in...
No picture when turned on. screen lines attepts
There two pieces of modules that usually go out, the power supply module or the backlight inverter module.
http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
Check to see if you do have 24vdc at the inverter board as shown in my pictures.
May 16, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Turn tv on get sound but no picture
Ur LCD inverter board is dead.This LCD inverter board provide the backlight for LCD panel screen to get a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish LCD inverter board for the replacement.This LCD inverter board is a long board in shape form.
May 05, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I can't figure out how to connect our dvd player to the tv. We also have a cable box and a tivo box. The dvd player has the cord with the red, yellow and white plugs on both ends but I can't figure out...
Look at the back or side of TV you will see AV in with the same colors Yellow, Red, White. Just follow the code and plug your DVD cable accordingly. Remember to switch the menu to AV to see the program.
Aug 14, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Directv remote code needed
Follow these steps:
http://support.directv.com/app/answers/detail/a_id/3188/~/white-remote-control-programming-steps
When it asks you to enter the code for your tv use 10178
It works like a charm!
May 01, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
32inch westinghouse LCD TV flickers/slighly shaky picture-LTV32W1
try reseating the LVDS cable inside the set it is the multi wire connector from the main board to the LCD panel (top portion of the panel). if that doesn't look to see if the back lamps are remaining lit during this problem. if they go out the problem may be power supply or inverters (lamp power supply).. some panel makers make these available as a seperate part, some do not and the panel must be replaced. if the back lamps stay lit it is the main board. start with the LVDS cable first.
Apr 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
46 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
