Question about Garmin nuvi 260W GPS Receiver
Stuck in USB mass storage mode.
I have had my Garmin 260W for a year or little over a year....for the past few months I have not been able to use it because everytime I plug it in to the car or a wall jack to charge it says it is in USB mode and it will not charge. I have tried resetting it numerous times and turned it on and off, can someone please help? Thank you.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Are these Garmin chargers and not an after market product? Please see this link:
    http://www.sharc.net/gps_charger_repair....
    If they are Garmin chargers, then your USB port connections are bad on your unit and either need to be resoldered or the entire USB jack needs to be replaced.
    - Jim
  • Garmin Expert
  • 343 Answers
Try a master reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 17, 2010
Mass storage mode usb
Common problem with this model is a loose USB port. More info on USB port issues can be found here:
http://www.sharc.net/gps_charger_repair.htm
Nov 11, 2013 | Garmin nuvi 1350 Car GPS Receiver
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say " usb mode. connecting to mass storage" then that will go away after a few seconds and then it...
The "USB mode" and "Connecting to Mass Storage" message will get displayed when the Camera is connected to the Computer and is recognized by the Computer as a Mass Storage device. This is not an error message and is a normal operation.
You can change the Mass Storage settings in the Camera (depends on the model) The USB Select or USB Connect option in the Camera can be changed to PTP, Mass Storage or PictBridge mode. Set the option in the Camera to PTP and connect it to the Computer and check if the Computer is recognizing the connection. Once the computer is recognized, it appear as a removable Drive.
You can transfer the images from the Camera to the Computer from the Removable Drive by copying and pasting.
Thanks for contacting FixYa.
Apr 07, 2011 | Sony Cameras
How to take a garmin nuvi 680 off usb mass storage mode
when you go to tools/settings there is an option for the sd card and you may take it off usb mass storage mode. or simply take out the card and put it back in.
Mar 26, 2011 | Garmin GPS
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
I just bought a Garmin 265WT. I ran the registration program, but the computer does not recognize the Nuvi. I've checked My Computer and it does not show a new drive ( the Nuvi should like like a drive...
Try these steps:-
  • Unplug the USB cable from the computer.
  • Turn the unit off and then back on again.
  • Plug the USB cable into your computer.
  • The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Also, in some cases the operating system does not support the device. Try upgrading it to the next higher level. In most of the cases windows Xp service pack 2 does not recognise this Garmin device. Try upgrading it to service pack 3.
If you are still experiencing the problem then you will need to contact Garmin for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 12, 2010 | Garmin nuvi 260W GPS Receiver
Won't charge
see how to fix mass storage mode
May 17, 2010 | Garmin nuvi 260W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
3,992 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
