Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
My steam vac seams to be blowing and not sucking up the solution. Help.
  • Anonymous Mar 09, 2009
    blows but won't ****!
  • cmaikoski Apr 25, 2009
    I had the same problem. "Best solution" worked great! Thanks so much!
    Problem Solver:
  • 4 Answers
I just called hoover support; their number is 800-944-9200.
Here are the three things the tech had me do:
1. pull up the front attachment panel and snap it back in to place; make sure it is secure - it becomes loose when you empty the tank.
2. make sure the attachment cover on the front of the machine (the hand brush is kept here) is securly closed.
3. snap the recovery tank lid on the two "hinges" on the back and snap the front closed.
This worked for me and I tried it several times to be sure it wasn't a fluke.
Posted on Mar 26, 2009
  • 294 Answers
The blowing is normal, it actually directs the warm air from the motor to the floor to aid in the drying process. check to be sure the lower tank front panel is in place and all parts are installed and secured. check the round seal under the lower tank to be in place.
Posted on Mar 15, 2009
Herlongspage had the best advice. that process did work. very contankous machine though. hovver should be paying for this site because without it; brand new machine #2 would be going back to the store, when it works it does a great job cleaning! but getting it to work is most troublesome. if i continue to have these difficulties, the machine will go back.
Posted on May 21, 2009
Shop Vac MAC 12-200D my shop vac is blowing air instead of sucking air. How do I fix it
this might sound silly but have you got the pipe in the blowing end instead of the sucking end hope this helps
Oct 09, 2016 | Shop Vac Vacuums
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Spinscrub loud brushes don't spin
Most models have a screen under the machine or behind one of the clear covers on the front. If the screen is clogged it will restrict the airflow.
Make sure the brushes will spin freely by hand.
Oct 06, 2017 | Hoover Steam Vac Dual V w/ SpinScrub...
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
It won't pick up the water and blows instead of sucks
Looks like a Dual V, I would check on the bottom to see if there are any blockages. and also above the dirty tank. Just try to clean out the filters and see if it helps, Good Luck!
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Upright Steam vac
Is there a float switch in the tank? Could be when the float rose up to a level it got stuck, stopping your machine.
Sep 09, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
1,531 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
