Question about GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave turntable
The plastic center that holds the glass has boken and will not allow turntable to turn.. how do I get a part? I have a freind who has one and we tried to get the part OUT there a way to take it out?
  • GE Master
  • 9,098 Answers
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
Posted on Mar 02, 2009
The glass turntable broke. Where can I find a replacement?
Go to Type: make and model of microwave, and refine search to glass plate.
Apr 02, 2012 | GE Spacemaker JVM1540 Microwave Oven
My ge micro will not stop turning
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE spacemaker XL over the stove microwave oven. Its 10 years old. The turntable quit turning. If I take the glass turntable off and put a glass of water inside, the motor will turn - sometimes...
This is a common problem in many brands, you have proved the AC voltage to the motor is fine, if there had a been an issue the voltage would have dropped while in operation causing a load on the power supply, since there was no change in the off/on stage it proves the motor is the problem and must be replaced to resolve the issue.
Jun 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The glass turn table wont spin??
Hi, Your problem lies with one or both areas. If you remove the glass turn table, you'll see a plastic grooved driver that goes thru the floor. See if you can lift up and remove it. Does it look broken? If not, there is a drive motor underneath that drives this plastic piece which turns the turntable. You'll need the model number to take to your local parts house for replacements. Hope this helps.
Jan 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable has stopped turning. is there a
It could be the plastic coupler part #942560. Remove your glass tray and lift up the plastic piece in the middle. It slides off of the motor. If it is broken that is your problem.
Oct 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable does not turn. How do I change the
The turntable motor can be replaced by following these steps:
1. Unplug microwave.
2. Open oven door and remove glass tray and carousel ring.
3. Locate and remove the screws holding the bottom panel (under the microwave) in place. With the screws removed, the bottom panel should open.
4. Disconnect the connector plug from the turntable motor.
5. Reach inside the oven and remove the coupler. This is the small plastic piece that the center of the glass tray sits on. You may have to gently pry up with a flat screwdriver to get it to come loose.
6. With the coupler removed, loosen the mounting screw(s) to the motor and it should easily come out from under the oven.
7. Install new motor in the reverse order of the steps I just provided.
This is a very simple repair. Ironically, I just replaced mine today. If you have any questions, or require additional assistance, please let me know. I hope this help you.
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not turn when on. I've checked the turntable button and it is on.
Make sure the glass platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced.To replace either part visit the web site If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
Glass turntable won't turn - spacemaker - XL 1400
Most likely a bad turntable motor - check with for a replacement .
Dec 23, 2008 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
94 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
