Question about Pioneer TS-W307D4 Car Subwoofer
Help with ts-w307d4
Hello all i have a pair of Pioneer TS w307d4 that i have blown i would like too where i can get them fixedat if at all
  • 93 Answers
The money to fix will be better put to some new ones.
Posted on Mar 05, 2009
What amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Jan 30, 2012 | Pioneer TS-W307D4 Car Subwoofer
I have a pair of pioneer ts A-6987 connected through an amplifier and pioneer cd player..i noticed today that the left speaker's cone woofer stopped working whereas the its producing voice but if very low...
double check the ratings on the speakers and amp. speakers that size don't usually require an amp. compare the wattage and resistance numbers, if you haven't fried an amp, you may have blown a speaker. another possibility is a short in the channel. check wiring connections.
Jan 29, 2011 | Pioneer TS-A6987 Car Speaker
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
Pioneer box
Thanks for using fixya!
I have had the same problem that you are having right now. I basically don't know how to start making my own sub box. Well, I chose the Bass-reflex type Box. This the best. Check this link out for a detailed overview of sub box making. http://www.hardwareanalysis.com/content/article/1789/build-your-own-10-inch-subwoofer/
Have a great day.
- HotRatchet
Jul 26, 2009 | Pioneer TS-W307D4 Car Subwoofer
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
I have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
Jun 07, 2009 | Pioneer TS-W307D4 Car Subwoofer
Which terminals to use
if your amplifier is 2 ohm mono stable - you can wire them in parallel.
Put a piece of wire from one + terminal to the other + terminal on the subwoofer.
Then do the same to the -.
Now pick one pair of teminals from the subwoofer and wire it to the amplifier. (one set of subwoofer terminals will have 2 wires each).
If you reply with your amplifier make/model, I can tell you the best usage.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 30, 2009 | Pioneer TS-W307D4 Car Subwoofer
Recommended vented box volume for tx-w307d4
pioneers are subs u have to be careful with, some subs are made for ported boxes and some arent, check if it is, tham if it is it should b tuned to about 35hz-45hz.
Nov 28, 2008 | Pioneer TS-W307D4 Car Subwoofer
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Mar 27, 2008 | Pioneer TS-W301R Car Subwoofer
My subwoofer will not go
Is the SUB connected to both channels? I will give you detailed instructions on how to connect a sub. Check out this website.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 03, 2008 | Pioneer TS-W307D4 Car Subwoofer
Pioneer TS-W307D4 Car Subwoofer Logo
141 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
