Question about Sony CDX-540RF 10-Disc CD Changer
Sony Xplod stereo reset problem
When I turn on my sony Xplod car stereo, CD source, the unit keeps telling me to reset. Hoe can I solve this other than ejecting the mag and re-inserting it?
Can anyone help?
Andy
  • Anonymous May 11, 2009
    I have same problem on my sony XPLod CDX car stereo
    New Friend:
My xplod deck wen I click on source it doesn't have aux anymore? How do I fix it so I can use my aux once again
Posted on May 26, 2013
4 Suggested Answers
  • 597 Answers
SOURCE: Sony CDX-M600R car radio CD: Radio does not work,
Don't know if you have an external antenna or one mounted in windshield but you should be able to find the coaxial heading towards the back of the radio. Make sure that it is plugged into the radio.
Posted on Jun 01, 2009
SOURCE: Have a sony xplod cdx-s2000 Cd-r/rw and no manual
press and hold the display button, the unit will beep, and the hour number will blink. press the volume up/down buttons to change the digit, press the select button, in the top left button of the faceplate to change from the hour spot to the minute spot, once the time has been set, press display again to save the time.
Posted on Apr 03, 2009
SOURCE: sony cdx-t69 CD Changer Unit
Bought a toyota with sony cd changer and had magazine stuck. Disconnected the cables at the back and left for 5 min. Hooked it back up switched to acc and pressed the eject button and came straight out. Didnt need to reset radio and retune.Now works fine.
Posted on Jul 01, 2010
I have a Sony explode disc was in it when I got and it plays but when I push eject it want eject it
Clarence, you are going to have to open up the stereo to manually eject the cd. There are several different models SONY has made of the "XPLOD" stereo. To make it easier for you, it would be a good idea to look on the back and note the serial number, or model number. For example, the steps to open up a touch screen "XPLOD" (XAV-63) is going to be different than a more standard (CDXGT150S). I hope this helps. Kick in some more info and I'll be happy to assist you further. ^^
Apr 25, 2015 | Sony Video Game Consoles & Games
Buttons of my sony mp3 xplod will not go off when i turn the player off
While the head unit is off press and hold in the volume or source (SRC) button it will bring up a menu with different options go to demo mode and turn it off hopes this helps thanks Jeff J&D services
May 15, 2014 | Sony XPlod CD Player w/MP3 Playback...
While listening to my sony xplod 52wx4 , the radio signal is fine for several minutes and starts breaking in and out with static. I have reset the stereo and the same thing happens. I have checked the
I'd hate to say, but sounds like part of your tuner is going out/bad solder join/heat sensitive. Hope it isnt to old. Might call the manufacturer and see what they have to say.
Jan 22, 2014 | Car Audio & Video
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
Aug 28, 2012 | Sony XPLOD CDX-GT200 CD Player
My aftermarket cd deck won't turn on in my Honda Civic. The Stereo is a Sony Xplod CDXGT700HD. I checked the fuse and replaced it for the hell of it. I tried using the reset button. I saudered all
You might want to check all of the fuses in the car. There should be a fuse box in the engine compartment and another under the dash somewhere.
Mar 21, 2012 | Car Audio & Video
Sony CDX GT200 does not work... is there a fuse in this radio? I cannot turn on the unit now. I just got my car back from the repair shop and they replaced my battery and alternator, but now my radio...
There is a fuse in the back of the stereo unit. Also trace the red wire from the stereo to where it's connected, and check the fuse for the circuit that the stereo is connected to.
May 22, 2010 | Sony XPLOD CDX-GT200 CD Player
How do i connect my blackberry curve to the sony mex 2500. Bought of ebay,no operators manuel. Regards
Easy!
1.) Turn off Stereo with the upper left button.
2.) Press and hold the EQ button just below it. the BT symbol will turn off, keep holding it, it will turn on, and then flash. when it flashes it is in pairing mode.
3.) go to connections/ Bluetooth on your phone and search for it. it will show up as XPLOD.
4.) the pairing code is "0000" enter and it will tell you connected xplod
to listen to music make sure it is in BT Audio, Also call quality is not that great, but it is an awesome unit to listen to some slacker/pandora over Bluetooth!!
Jan 05, 2010 | Sony MEX-BT2500 CD Player
When i press the source button it will not change to cd and when i press the eject button the cd will not come out
On my CDX-GT20W, when it would not change to Aux input, I had to remove the faceplate and press the reset button to Reset the unit. The reset operation put everything back to factory defaults....which meant reprogramming all station presets, however, the entire unit functions as new. Hope this helps. Page 4 covers this.
http://www.docs.sony.com/release/CDXGT50W.pdf
Sep 29, 2009 | Sony Xplod CD Player w/MP3 Playback...
Sony CDX-540RF 10-Disc CD Changer Logo
1,737 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
