Question about Goodman GDS80904BNA Open Flame Heater
Need the cubic inches for the return air duct
I am setting up return air for a new goodman furnace. There will be two return air ducts that travel through the house. I don't know the cubic inches these two ducts need to be. The two return air ducts will come together at a 10 inch by 20 inch main return air duct at the furnace. The duct work has to travel through the house and I am not looking for the length, but the cubic inches of the end of the two ducts combined. the furnace I have is a Goodman model number GMH80904BN. The product number below has the letter "A" at the end of it and mine does not.
    Novelist:
  • 189 Answers
For proper minimum opening you need to do duct calculation. This is not a typical math equation for the typical homeowner. And unfortunately alot of contractors do not take the time to calculate this.
If you insist on doing this yourself...... I would recommend the largest opening that a common filter will fit. probably 20" by 25". Going to big on a return air will never hurt. But going to small will.
20" x 25" will work safely 95% of the time. But... If you are running airconditioning that is 5 tons in size, you will need the design a return air system that will feed from BOTH sides of the furnace.
If you are just sizing the trunk line you should use a ductulator to calculate the minimum size. A good rule of thumb would be to size the "return air" trunk 1 - 1 1/2 times the size of the supply trunk line.
Posted on Mar 08, 2009
How do I can the air filter in my unit?
Hello, the filter will usually be on the return air side of you furnace. It will be where the return duct meets the furnace and the filter should be in placed into the filter rack
Mar 20, 2011 | Goodman CLQ36AR49 Air Conditioner
I have a 4 year old goodman furnace. Is there a filter on it? If so where would it be...i would like to change it.
iS THIS A GAS OR IOL FURNACE. iF GAS SHOULD EITHER BE PANEL OR OPENEING ON SIDE OF RETURN DUCT. or where return grill is in house.
Jun 24, 2010 | Heating & Cooling
Intake vent needed?
The blower motor is only going to pull a certain amount of CFM for circulation air. There is some restriction of air flow that is created when the return air system is ducted causing the air flow to "slow down" a bit. The air going into the furnace firebox is probably moving at a faster rate than if the return air was ducted. It will work and you will get the same amount of heat (energy) released but the faster moving air will make it feel cooler. Also the unit might be undersized(BTU output) for the size of the cabin and amount of airflow the blower is creating. Adding a extra filter(double) might slow down the air flow a bit to create more warmth(feel) coming from the registers. Also if the furnace and air intake is pulling air from outside(garage,closet, or under house) then the colder air from outside going into the system will decrease the heat from the furnace. It is better to have a closed system (return air inside cabin). You might want to try adding a extra filter to slow the air flow down some or use some sheetmetal and square it from the intake to try and concentrate the incoming air a little better and see if that improves the warmth coming from the furnace.
Jun 16, 2010 | Goodman GMS90703BXA Heater
Need to locate filter on model PGJ042100-1
Filters are usually added to the sheetmetal seperate from the furnace. All air must be filtered before entering the furnace. Turn on heat and feel ductwork to determine which direction air flow goes, warm will be supply and room temp. will be return. Filter should be on return side of furnace. Some of them may be filter grilles located in a central reurn on older homes with only one return in a hallway or sometimes the correct ductwork is not installed and they are inside the bottom panel where return ducts connect
Feb 02, 2010 | Goodman Heating & Cooling
I have a goodman furnace (GME-8) and i cannot locate the air filter?? any idea where i should look?
It should be in the return air duct. The place the air is removed from the building on its way to the furnace.
Oct 27, 2009 | Goodman Heating & Cooling
Goodman furnace went out. Light blinks four times
Your main limit switch is activated. Maybe for good reason. This switch keeps the furnace from overheating. I have the same problem right now and I think my a/c coil may be blocked, limiting air flow through the heat exchanger and the furnace. Does your gas and main circulating fan come on for a few minutes before the switch activates and the light begins blinking?
Check your furnace filter and any return air ducts in your home - see if they are blocked or restricted.
Jan 14, 2009 | Goodman GMS90703BXA Heater
Not enough return air to heating unit
Right now you are at bare minimun for what your unit requires. If you are not having any problems with the unit or have not had any I would not worry about it. You need to check and make sure that your duct size on the unit is not smaller than 14" in diameter. If it is 14" or bigger you are fine.
Dec 03, 2008 | Goodman CLJ30AR32 Air Conditioner
I have had a new honeywell humidifier installed. The problem is the control H8908B. HE INSTALLED IT FIRST TIME ON A DUCT RIGHT NEAR THE FURNACE AND IT FEEL OFF . Melted . Then came in and moved it away...
After the air leaves the fan ,this is called supply air ,before the air enter the fan which sucks air into the fan --- on the flter side --is called the return air!
Sep 12, 2008 | Honeywell Heating & Cooling
Goodman PCK-060-1C. suction 52, coil/filter/blower/restrictor/drier okay. Recovered the charge and recharged with factory specified amount. The return air 1800 cfm. Motor 3/4 hp. It seems to me the motor...
It seems to me that your suction should be @ 76 or so. 52 is low. the coil will ice up with any suction PSI below 58. Disconnect the unit from the duct work and make sure there is no restriction in the duct size. In other words. Does the unit work properly with out the duct? I find most mobil homes have a restriction in the amount of return. A 5 ton split needs a 20 inch round return. You never see this size return on a package unit. Does the return **** the filter in? I have had to add returns to large mobil homes because there just not designed right.
this is only a possibility. Is the temperature split on the equipment between 18 and 20 If it is then I don't thing you have an equipment problem. Also make sure there are no holes in the duct work.Last one I had unit was working fine but the duct work had a big hole in it from some animal under the trailer.
May 13, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
215 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
