Two baffles are really loose. I have the new baffles, but don't know how to get to the outside of the drum, to screw in new ones.
SOURCE: How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
SOURCE: Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
SOURCE: Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
SOURCE: My Maytag dryer has a loose dryer drum baffle.
unplug Dryer, open door, Remove two door hinge screws going into front panel, remove two screws on opposite side. Grab front panel on upper sides and twist and pull front panel out. Panel sits on two clips at bottom so you have to tip panel out to unhook from the bottom. You will see a metal hook with two screws in it that holds down the top of the dryer on each side. Remove the screws and hook bracket. Make sure you note how it reinstalls. Top will now lift up and lean back against a wall. It is hinged in back. You can now easily get to the drum baffle screws. Good Luck, Appliance Specialists
Testimonial: "I will try that quite soon. Thanks."
