I changed my heater core, all the settings work, but the digital cold to hot bar on the bottom of the heater display blinks with all the arow lit up but the air is always cool. I checked the fuses but they are fine. help please
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
The blend door actuator may be bad. Located behind glove box on top of the box left.
Does anyone know if the 94 Yukon heat system controls the cooling fluid with a valve at al or not?
You bled system properly with rad cap off & heater on after changing core?
