The hose broke off with about an inch of the plastic tip still in it. how do i replace the fitting without removing the heater/air cond. assembly from inside under the dash? is it possible to remove the rest of the fitting and replace it, i tried pulling the rest of it off but it won't budge, it will turn, but it wont come off
Unfortunatly the short answer is no you cant, Gm and others started making heater cores and radiators out of plastic. The result has been that after the plastic gets hot and cools a few hundred times it gets brittle, hence your problem. Unless you are very good mechanically I would advise letting a pro do it for you.
