Question about Toshiba Satellite A135 Notebook
HL-DT-ST DVDRAM GMA-4082N ATA Not Working
I have a Toshiba Satellite A135-S2276 Laptop with a DVD ReWritable disk drive (HL-DT-ST DVDRAM GMA-4082N ATA Device) running under the vista os that keeps disappearing. When it disappears I check the device manager properties page and it disappears from that page also. Then I restart the computer then it reappears for a lil while and then disappears again. I even tried a complete restore on the os and it does not fix the problem. It is intermitently off and on(after retart). It of course stayed on and read the restore disk to do a complete restore but it wont stay on for anything else. I tried to do this: Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} but it has no UpperFilters and LowerFilters values (Even when the drive is working). So I dont know what else to do. Can somebody help please.
Thanks in Advance
    Novelist:
  • 148 Answers
Check the drive itself and see if it isn't loose in the carriage. Make sure the screw that holds it in place isnt loose or missing. Try this as a test: shut down the laptop. Press and hold the faceplate of the drive. While holding the faceplate, turn on the laptop. See if Windows detects the device again. If not (while still pressing on the faceplate) go to Device Manager and see if Windows sees the drive again.
The above trick you used is in case a CD burning program was improperly updated or uninstalled and it damaged the identifying drive filters. Each of those entries has more than one set of reg entries in the keyset. Make sure youre looking for the one for the CD/DVD drive. DO NOT DELETE entries for any other devices!!!
Posted on Mar 02, 2009
2 Suggested Answers
  • 107 Answers
SOURCE: many the following registry subkey: HKEY_LOCAL
Hi, I believe you are an experiencing an issue with the CD/DVD drive on your computer.In the registry the following subkey:- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}-upper filter/lower filters should not be present if they are present that would effect the functionality of the drive.Please check whether you are able to view the contents of the CD/DVD by going into computer right click on CD/DVD drive icon and then click on open and if you are able to view the contents of the DVD/CD then the drive is working fine and please try the following steps:- One of these may help:
1. Download, and run Restore Missing CD Drive patch
Double click on cdgone.zip to unzip it.
Right click on cdgone.reg, click Merge.
Accept registry merge.
Restart computer.
or...
2. Go to Device Manager, click a "+" sign next to IDE ATA/ATAPI Controllers.
You'll see two items:
- ATA Channel0 (or Primary Channel)
- ATA Channel1 (or Secondary Channel)
Right click on each of them, and click Uninstall. Confirm.
Restart Windows. They'll be automatically reinstalled.
Incase this doesn't work please perform the below menioned step:- Go Start>Run ("Start Search" in Vista), type in:
sfc /scannow
Click OK (hold CTRL, and SHIFT, hit Enter in Vista).
Have Windows CD/DVD handy.
If System File Checker (sfc) will find any errors, it may ask you for the CD/DVD (rarely in Vista case).
If sfc won't find any errors in Windows XP, it'll simply quit, without any message.
Thank you for your patience and best wishes for your effort.
Posted on Jan 11, 2011
Testimonial: " thank... so much I try / may be I ask you again.."
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the...
backup whatever information you have and run the system recovery through the disks you received when you purchased the computer. If you can perform the recovery then you know the hardware is fine and that you were experiencing software corruption.
Nov 16, 2009 | Toshiba Satellite A135 Notebook
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
HL-DT-ST DVDRAM GMA-4082N. Can not write to DVD
The DVD -R +R means that you can read these types of DVDs that have been created elsewhere, it doesn't mean you can write to your DVD under the format of -R or +R. The CD is a CDRW which means you can read and write to CDs.
I don't think that a factory Satellite P100 has the ability to write to either DVD -R or +R, but to only CDs. I have a P200 that has a DVD -R +R/CDRW and it can't write DVDs. These DVDs you put in are for read only. My Toshiba A215 can but it's a DVDRW/CDRW.
Feb 15, 2009 | Toshiba Satellite A135 Notebook
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
this is due to the fault of the device you should replace it
Oct 02, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
check whether the device is detecting properly on bios or not
Oct 01, 2008 | Computers & Internet
Not work
Try this...
http://support.microsoft.com/kb/929461/en-us
It should clear out error code 10
hope this helps...
Jul 25, 2008 | Toshiba Satellite A135 Notebook
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
Jul 20, 2008 | Toshiba Satellite P105-S6104 Notebook
Thank you for using Fixya.com and glad to hear to got your monies worth.
Regarrds,
Worldvet
Jun 08, 2008 | Toshiba Satellite P100 Notebook
Go back to the device in device manager, right click on it and select properties, then under the driver tab click on "Roll back driver" button and see if that does the trick.
May 07, 2008 | Toshiba Satellite P100 Notebook
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Dec 10, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite A135 Notebook Logo
569 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
