Question about GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1800 turntable turns sometimes
With nothing on the glass plate, or with a light item, it turns. Moderate to heavy weighted items no longer turn. Started a few weeks ago. Microwave been in use for about 3 years.
  • Anonymous Mar 21, 2014
    My turntable quit turning -- sometimes if very light item it will turn very slowly.
  • GE Master
  • 9,098 Answers
I would say an internal post broke inside the motor. This often happens when a heavy item is placed on the tray.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 02, 2009
Microwave makes grinding noise when microwave plate on turntable
check for the roller spider under the plate
small plastic item that has 3 (4) rollers that allows the plate to turn freely
May 25, 2015 | Microwave Ovens
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Purchased GE Microwave, JES1142 in March, 2008. Recently I am having problems when heavy items such as cup of coffee or heavier is placed on turntable. The turntable does not turn and the light does not...
hi nurse becky,
have you put the roller that comes with it?.. normally there is this plastic frame that you place at the bottom of the microwave and it has three rollers that would your turntable motor turning even if you put heavy loads on it. if has one, kindly check each roller if they are turning smoothly.
i hope i was able to help
kindly rate me please
tnx,
drcool
Jul 19, 2008 | Microwave Ovens
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE XL1800 JVM1870SF02
I have the same problem on a Jenn Air. Did you get an answer?
Oct 03, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 Microwave
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Nov 30, 2006 | Samsung MW1030WA Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
