Question about HP OfficeJet 6210 All-In-One InkJet Printer
How do a clear a carriage jam on a hp6210 printer
Evertime I try to make a copy I get an error clear a carriage jam on a hp6210 printer .......but I see no jam anywhere. what do I do?
  • Anonymous Mar 07, 2009
    same as described. Message says to open door and clear carriage jam. I have opened every door and inspected with a flashlight...no jam.
    Is this a bug maybe?
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Throw the machine away and buy a new one.
My HP6210 printer had the same problem. The carriage would make a lot of noise going back and forth and I got the carriage jam error message. Using a flashlight, I found an incredible amount of ink (mainly black ink) underneath the mechaism which clears the ink off the print cartridges. I throughly cleaned the internal components and it works again.
Posted on Mar 07, 2009
I just lift the cover up and hit OK. May have to do this a couple of times but it seems to work. May also want to insure that the plastic feed track housing is securely in place. This housing snaps in and out and sometimes get dis-lodged.
Posted on Mar 06, 2009
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp photosmart printer is saying Error carriage jam, open dorr clear carriage jam and then press Ok to continue. Which door should I open and how do I clear the carriage jam? Linda
Without any paper in the machine I would try powering off and powering on. Lifting the scanner lid will clear so the carrige goes back to the correct side of the printer. Even rebooting the printer and loading the software will sometimes cause the carriage to go back to where it was supposed to be.
Jan 16, 2010 | HP PhotoSmart C4180 All-in-One Color...
Error message reads "carriage jam"
The print carriage access door is the large top part of the printer that swings up. If you look in the user guide it is arrowed on page 14.
If you don't have a copy you can download it here:
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Hope this helps
Jan 13, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
My printer is a hp6210 and the error I am getting is carriage jam, open door clear carriage and press ok
The carriage is what holds the ink cartridges. If you open that and make sure that there is nothing that is blocking the carriage from moving. If there is remove it. If the machine is powered off you should be able to slide the carriage by hand back and forth along the metal shaft that it rides on. If it feels like it is sticking you can wipe the shaft off with a clean lint free cloth. DO NOT add and oil to the shaft. Power the machine back on and it should work. If it still errors out you will probably have to bring it to a repair place.
Hope this helps
Dec 04, 2008 | HP Office Equipment & Supplies
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Jan 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
337 people viewed this question
Seeker5211
Seeker5211
