Question about Sharp Office Equipment & Supplies
Heater bulb does not light, copier prints black page
I can't find access to the bulb. Where is it located and how do I change it?
  • Don Johnson
    Don Johnson Mar 01, 2009
    Help me if you can.
Call a technician. You can't get one of these at your local hardware store
Posted on Mar 01, 2009
How do i change scanner light bulb on hp psc 1205 printer
Most of the time the light bar is not the problem when it comes to print quality issues. Those are typically ink cartridge or printhead issues. Try printing a self test page and compare.
Dec 19, 2014 | HP PSC 1205 InkJet Printer
Dimplex heaters CHB20BR owners manual how to change the light bulbs?
Changing the bulbs in your model is quite different than changing the ones in a full electric fireplace. Yours requires a bit more dismantling and removal of parts. So, I have provided a link to the Owner's Manual just in case you have misplaced yours. What you need to know is on Page 14 of the manual.
For future reference, I suggest that you download and print the manual. Then keep it in a safe, accessible place.
I hope this helped you and thanks for choosing FixYa.
Sep 23, 2011 | Dimplex DFI2309 Electric MidSize Heater
Bottom bulbs don't work
Sounds light the 2- 60 watt small base, chandelier bulbs need changing. To access the bulbs and change them does require some dismantling of the base of the insert.
In case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference. Pay particular attention to Page # 5 - Maintenance - Changing Light Bulbs.
Hope this helps you solve the problem. Please let me know. Thanks
May 07, 2011 | Dimplex DFI2309 Electric MidSize Heater
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
Xerox Phaser 7700 printing Black line across bottom of every page
The line could be caused by contamination on the black laser lens. Try using the cleaning wand located in the front door to clean the lens. You will need to remove the waste toner container to access the wand slots. If that does not solve the problem, the black developer housing may need to be replaced. Refurbished parts at:
Apr 23, 2010 | Xerox Phaser 7700 Laser Printer
MP830 prints lightly about every 2 cm down a page from computer.
Sounds like it's in draft mode...
On the MP830 locate the "settings" button (top right of the cursor circle and left of the 1 key).
Press "settings"
This should give you the "Print Quality" settings page on the LED
Locate the 3rd field down which probably says "Fast", change this to "Standard"
Press the "settings" button again to register the change.
Also possible that your contrast is causing problems... Check to see where the red bar is in the gradient (white to black line) under the "Copies" field on the LED in copy mode. If it's way over to the left that would also explain some of the problem.
Pressing the right arrow key on the circle controller will increase contrast although I'm not sure if it will retain this setting.
Hope that helps.
Jan 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
The copy function prints a solid black page?
Do you see the light going all the way across? The printer may be having power issues. You should make sure it is plugged into the wall and not into a surge protector or a power strip.
If the light is not coming on then there is an issue with the scanner bulb and if the printer is plugged into the wall then you should call hp and see if you can have it replaced.
Jan 21, 2008 | HP Photosmart C4280 Aio Printer
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
