An it stall out whn i come to red light or complete stop
SOURCE: 1992 mazda B2600 ute
find the oil pressure sensor on the block and unplug it the light should go out, if not try grounding it if it goes out make sure you have adequate oil pressure and change the sensor please rate -jeff
SOURCE: mazda precidia 1992 stalled alot
need ot know when it stalled, as in what did it do when it stalled, how it sounded, Ect.
SOURCE: 2006 Mazda Tribute: Gas pedal keeps sticking when I excelarate!
locate the cable from the motor. disconnect,hold up high spray wd-40 into cable,lots cause you want it to run all the way through
SOURCE: mazda mx 3 1992 not start
Check for possible vacuum leak, maybe a hose off or partially broken. Make sure your firing order is correct when reconnecting those wires to the new cap.
