Laptop charger melting
I recently had trouble with my laptop charger, which was purchased a year ago. At first the charger would keep flashing on and off, then the other day whilst plugged in the charger end melted. What is the cause of this problem, and would it affect my laptop functioning in the long run seeing as it was plugged in when it melted. Would i still be able to use another charger on the laptop?
  • david99126 Apr 05, 2009
    more or less the same is happening to my 2year old laptop. the charger has melted and the metal charger is stuck inside the laptop and will not come out.
    when using the laptop charger connector tip (the metal bit) gets incredbly hot.
    does the problem reside with the charger? the laptop? or what?
    and how do I remove the charger connector tip from the laptop!!
    ps. fujitsu-siemens amilo pi 1536 . original charger . laptop doesn't overheat . laptop still works fine
This also happened to me :( yes you can use a dirffeeent charger but it is Likly that it would happen again I use my moms and it starts melting but when it is plugged into my moms computer it doesn't so probably our laptops just draw alot of power :
Posted on Jun 28, 2011
  • 948 Answers
The cause was high resistance in the charger, probably from a poor solder joint. It is likely your laptop was not damaged. You can use another charger.
Posted on Mar 01, 2009
Lenovo laptop sparks when charger is plugged in
Normally this should never happen. There is definitely something wrong with your laptop charger. You should stop using it. You can purchase replacement from stores such as ebay, amazon, google shopping, and etc. They are the cheapest compared to the your laptop brand's company. However, their prices and policies also vary greatly.
Personally, I would suggest buying from
According to your laptop model, you may search the correct replacement lenovo charger from the following link:
This is where I bought my laptop charger sometime ago, and it is still working fine. Although their price is in the mid-range compare to the places I listed above, the price is much less than the original brand.
Moreover, this reasonable price comes with a year warranty. You should really take this website into consideration before purchasing. Their warranty and policy are very clear.
Hope this helps! Best of luck!
Jan 13, 2013 | Lenovo Computers & Internet
Acer aspire 5750 charging problem
The solution to your problem lies in one of the following three areas:
Your charger is faulty and is therefore not able to pass power to your laptops battery.
The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
Your battery is faulty.
If you are sure that your laptop charger is dead and you are in the market for a new one, try the following one:
Replacement Acer Aspire 5750 AC Adapter 90Watt 19V 4.74A
Oct 30, 2012 | Computers & Internet
My laptop is an Asus 1005HA-V and I'm having trouble turning it on. I've had it for about a year and when I try to turn it on it's lights flash and then turn off again. Also sometimes when it's on the...
Things that you can try:
1. disconnect the charger and the battery. 2. press and hold the power button for 15 secs. w/o the charger and the battery (the reason for that is to drain flea power). 3. connect the laptop straight from the charger w/o the battery and turn it on. It should turn on fine. If nothing happens, the motherboard is bad or the charger.
Jan 17, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have had an Exilim EX-Z75 for just over a year. Suddenly I'm having trouble charging the battery. No matter how long I leave it on charge the light keeps flashing and the battery is not charged. Do I...
Yes you need a new battery. I had the same problem almost exactly a year ago. You need to contact Casio and tell them the problem, they should send you a new battery free of charge. This is the proper number to call, 1 800 435 7732. Just tell them your battery charger is flashing red when you are trying to charge and they will send you a new battery.
Feb 21, 2009 | Casio Exilim EX-Z750 Digital Camera
Dell 600m Laptop Killing batteries
If you are using known good batteries, and you have the most current BIOS Flash, then it is likely a failure of the charging curcuit on the motherboard. The flashing Amber (Some people see it as red) led indicates a failed battery
The Multiple good batteries, I assume have been recently purchased, because computer batteries are consumable and are rated for 300 to 500 charging cycles before they wear out.
I replaced my 700m motherboard with one from Ebay for about $170.00 about a year ago.
Jul 05, 2008 | Dell Inspiron 600M Notebook
Battery Charge error
Hey Lak_69,
One problem I know of is the battery for your camera should be model NP-20 not model NP-40. The NP-20 has 650mAh. I would exchange your new battery for the correct model battery, and see if this works. If this doesn't work I would try cleaning the battery terminals in the camera, and if that doesn't work go ahead and try a new charger.
Go Ahead. Use Us.
May 13, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Computers & Internet Logo
646 people viewed this question
David Payne
David Payne
