Trying to take pictures of a full moon on a clear night. and how do I change the ISO Thank You Tina Kocsis
You're going to face two separate problems here.
One, the moon occupies a rather small portion of the night sky. Even fully zoomed in, the moon is going to be not much more than a bright spot in the sky.
Two, the camera is designed to assume that almost every scene is an average brightness. Given how much of the scene is a black sky, the camera will attempt to render the sky as average (what photographers call a "medium gray"). This will result in a picture with a gray sky and a featureless white blob for the moon.
If you think about it, the full moon is nothing more than a really big rock under a midday sun. Thus what you want is the same exposure as when taking a picture on a clear sunny day. Unfortunately the camera is going to be fooled by all that dark sky and try to compensate for it. What you really need is to be able to bypass the camera's light meter and set the proper exposure yourself. The C195, unlike more sophisticated cameras, doesn't allow you to do so. Sorry, but that's just the way it is.
Set camera on a tripod and ISO on automatic will usually get a good picture
SOURCE: FUZZY & BLURRY PICTURES.
It could be the focusing, did you check the focus every time? A slow shutter speed also causes blurry pictures. I know you do use your tripod, but if you don't use the self-timer function or a shutter cable then you are not using the tripod properly. Also, check the front piece of glass in the lens, clean it if it has stains or whatever on it.
