Hi
Try this out
The 6A00 is a Canon generic code for paper path jam.
Solution 1: Move the printhead carriage back and forth a few times.
Solution 2: Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3: Press the ink pads down in the purge unit. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Hi Error 6A00 The 6A00 is a Canon generic code for paper path jam.
Hi
Error 6A00
Hi
Error 6A00
Hi
All the best
Canon lists the solutions for the error 6A00 as... 1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. Removing paper jams 4. The MP830 may require repair 5. Unlock the scanner lock switch (MP830)
6A00 means the purge assembly is jammed. That's the unit that cleans the printhead. Sometimes it will last a while when cleaned, but I just replace them.
QM2-3032-000 about $20.00 but much easier at a shop.
Ok try this
Error 6A00
6A00 means the purge assembly is jammed. Look inside to the right where the printhead rests when turned off. Remove any paper scraps. Otherwise you need a new purge unit
QM2-3032-020 around $30 for the part.
Hi
Error 6A00
