Question about Crosley CDE6000 Electric Dryer
Crosley CDE6500AZW heating, but drum not rolling
The problem happened after an indoor flap to the outside was installed backwards, preventing the air to vent out.
One cycle was done like this. After cycle was done, clothes were still very wet. I fixed the flap so that it lets the air vent outside properly.
We then started the dryer once again and the dryer ran for about 10 minutes and then stopped on its own.
Now, when we turn it on, the heating element heats up, but nothing else seems to be working. The temperatur is set to Regular for the above. I've tried on the temperatur setting for Air Fluff and Low setting, and same result, except for Air Fluff, I don't hear a click that I hear for the Regular setting.
Also, when element heats up, a distinct burning smell can be detected (the kind of smell when an electric heater has not been turned on for a long time and dust has accumulated on the elements).
For the
  • Brian Richard Mar 01, 2009
    I've opened the top and checked the belt and it looked fine.
    A new symptom though, the light inside the drum doesn't come on anymore.
  • Dan Webster
    Dan Webster May 11, 2010
    Broken belt?
  • Crosley Master
  • 8,220 Answers
OK Here is what I think happened. I have heard of this before. You melted a wheel and that broke the belt. This is a simple dryer to repair and parts are not that much. Well worth fixing. Start by popping the top remove the front then get the drum out and inspect the damage.
Posted on Mar 01, 2009
  • Dan Webster
    Dan Webster Mar 02, 2009
    The fuse may very well be blown. But that would kill the dyer. Did you say the dryer will run?
I currently live in the midwest and today has been an extremely humid day (90 degrees+ and 84%+ humidity). I used our LG gas dryer (Model # DLG2241W) earlier this weekend and it worked fine. Tonight, when...
Water in the drum anytime after drying a load of clothes is not normal.
Was the load prior to you having found the condensation fully dried? If not, check for lint in the vent system and make sure that air is coming out of the vent (the flap or louvers on the vent cap should open fully on a short vent line). Even so, this would not account for a small amount of standing water in the drum.
The first thing that came to mind was outside air being drawn in through the vent. If you have air conditioning and a well-sealed house, the warm, moist air hitting the cool drum (in a relatively dry atmosphere) may cause condensation. Check the outside vent to ensure that the vent cap flap (or louvers) is (are) closing all the way. Convection or air flow from the basement to a vent fan in an upper level might cause this.
Please let me know if I can help further.
Jul 18, 2011 | LG Dryers
Heats up, drum spins, takes 3-4 cycles to actually dry clothes
dryer vent hose is pluged or pinched against wall remove from back of drier and check hose also check outside vent it should have a flap make sure flap opens also make sure there is not a screen in outside vent sometimes roofers get them mixed up with bathvents
Apr 12, 2010 | Whirlpool Inglis IP8200 Dryer
My Inglis dryer has condensation on the inside of
normally condensation on the inside of a dryer is due to a pinched or plugged vent hose i have had this happen also when the dryer vent is very short and goes outside where the temperater outside is cold and moisture will condense on inside of dryer
if you live in a colder location there is a vent system
that you can install that will allow you to keep heat inside not reccomended for gas dryer the vent cap on the outside could also be missing the flap that stop air from going back into dryer hope one of these suggestions i a solution to your problem
Dec 10, 2009 | Whirlpool Inglis IP8200 Dryer
Do vented range hoods blow air into the house?
sound like not installed right,most hoods are convertible and the blower must be rotated to vent outside. Hopes this helps,please rate my solution :)
Jun 25, 2009 | Kitchen Ranges
Gets warm but not hot enough.
Occaisionally this is due to either dryer being set to a 'delicate' or 'low' setting. Most frequently it's due to an obstruction in airflow so the heating coil is cycling off to prevent overheating. The vent at the back of your dryer should be cleaned out (by sucking out the lint with a vacumn hose) at least once a year. The vent pipe out of your house as well. Make sure that the flap on the outside of your house is opening and allowing free air circulation when the dryer is on. And make sure you clean your lint trap every time you use the dryer.
May 03, 2009 | Dryers
No cold air blowing from vents
faulty indoor fan motor, check for blown fuses first in the indoor fan unit first before replacing motor. i live in s.a to i feel your pain.
Jan 29, 2009 | Heating & Cooling
Venting hood to outside wall.
install ducting along with closing flap (so outside wind does not blow in) and power first !
Jan 25, 2009 | Jenn-Air JXT8142ADS Kitchen Hood
The problem is the dryer was taking too long to dry. Ive taken off the front and started the dryer, the heating element glows red ang ignites the gas, then goes out after about 45 seconds. The ignitor and...
If you run the dryer with the front off, the air is sucked in the open front and out the vent. The combustion air (and heat) is not drawn away from the burner, which causes the burner to short cycle. You may also have this same condition with the front on if you have a poor vent. Don't use any flexible venting. Use rigid aluminum pipe and adjustable elbows if needed. Clean the vent out and make sure the outside vent is clean and air flows out the vent with a strong flow. The outside vent should be a 4 inch vent, not a 2 inch vent flap. That normally will solve your problem. Rarely, a gas valve may cause these symptoms, but make sure the vent is good first.
Dec 15, 2008 | Dryers
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cold air from outside coming in house through vent
Sounds like your damper (flap) outside is working, and that's probably the first thing to check. Wind may be also pulling the damper open from time to time. Hopefully the pipe fitting is sealed, and the pipe is insulated anywhere it runs through any unheated portion of the house. Some amount of cold air getting in will be unavoidable. The best bet next might be to look over the two pages in the installation instructions that deal with outside venting. If you don't have the installation instructions, you can get a copy here: http://www.geappliances.com/service_and_support/literature/ Then if you don't notice any obvious problems with the installation, it may be time to contact the installer for their two cents.
Feb 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Crosley CDE6000 Electric Dryer Logo
94 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
