Question about Toshiba Satellite M45-S359: M45-S359 Centrino 750 2.0GHz, 1GB RAM, 100GB hard drive, DVD-RW/CD-RW, 56K Modem... (SATELLITEM45S359M45S359) PC Notebook
Internal Hard Disk Upgrade
Is there a larger than 100 GB capacity internal Hard disk drive upgrade for Toshiba Satellite M45-S359?
  • r_v_o1 Mar 02, 2009
    Thank you, Beamsabre, helpful technical advise.
  • Anonymous Mar 25, 2014
    My Satellite Pro C850-10L has a 320 GB HDD and I want to upgrade to 500 GB, which are the specifications I have to consider for buying the new HDD?, remember, I want one like the one that came factory installed, but with a bigger capacity (500 GB or more). My laptop Part N? is PSKC9E-00600 MCE.
    Novelist:
  • 148 Answers
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Posted on Mar 02, 2009
Max hard drive size for Toshiba Satellite 2430-S255
Unless you are running Windows 3.1, Windows 95, Windows 98 and your drive format is FAT16/32 and not NTFS, there should not be any problem with a high capacity drive. Don't make the HDD size too big: it may be costly. If you have money to burn get two drives, one internal system disk, and the other an external storage/ backup drive.
Dec 14, 2013 | Toshiba Satellite 2430-S255 PC Notebook
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Replace laptop hard drive or replace laptop. Current 80 GB Toshiba?
It depends on what you run on this laptop ..but if you only run windows xp ..you do not need a larger hard drive ..and if you only need space to store data ..you can just get a usb external hard drive and avoid the trouble ..The hard drive will be fully usable in other computers too and this is the advantage if you will upgrade in the future to another one with high performances ..
If you have at least a 1.6 cpu on it ..and 1 G of ram memory and you think you may run windows 7 ..you can upgrade it to a larger hard disk ..but remember that this one runs on ata ..and I'm not sure it worth the trouble .
If you have at least 1 G of ram memory on it you can run windows 7 with this hard disk too ..but you will probably have to change the partitions configurations and make C drive at least 40 G so to have space to run it proper..
let me know if you have other thoughts related with this matter ..and i will answer it ..Please rate my answer to help my activity here ..thank you ..!
Dec 19, 2011 | Toshiba MK8025GAS 80 GB Hard Drive
Toshiba Satellite Notebook M45-S351 I recently purchased an upgraded hard drive - 160 GB Samsung Spinpoint and upgraded the RAM (Crucial 1 GB, bringing the total to 1.5 GB of the allowable 2 GB). Impetus...
Remove thwe new RAM and hard drive. Does it boot to the BIOS menu? If yes, add the hard drive and do the same again then add RAM and do the same.
I suspect something does not fit in properly. Probably the RAM.
Don't forget to initialise the hard drive if trying to format it. The System disk should take care of that.
Dec 21, 2010 | Toshiba Satellite M45-S351 Notebook
Has anyone upgraded an Epson P-5000 hard disk to a larger capacity drive? if so how is it done?
Hard Disk Upgrade Can I upgrade or install a larger hard disk drive in my Viewer?
The P-5000 includes an internal 80GB hard drive which is specifically designed to work with this product. There are no hard drive upgrades available for this product. If you try to install another hard drive, it may damage or adversely affect the operation of the product. This type of damage or operational failure is not covered by the product's warranty.
Mar 30, 2010 | Cameras
I need to upgrade my internal hard drive, what exactly do I need to get the most storage for my Toshiba Notebook Satellite A135-S4666? I would like to have 500gb or more of storage.
There are two kinds of hard drives and you must learn which one your computer has. To do this, Turn the computer off, diconnect the power chord and remove the battery. Locate and remove your present hard drive.
If the connection end of the drive has two plastic covered connection locations, you have a SATA drive.
If the connection end has more than 40 pins, you have an IDE drive. There is no way you can confuse the two types.
Go to your favourite computer parts source (ebay, web store or real store) and buy the largest drive that they have and that you can afford. Install the drive and install your favourite Operating System.
The largest IDE drive is 320 GB and the largest SATA drives I've seen are 500 GB. Best of good computing with your new drive.
Jun 23, 2009 | Toshiba Satellite A135-S4666 Notebook
Hard disk capacity increase
yeah you need to replace the old hard disk to new IDE 120GB hard disk.
Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
Upgrade Possible?
Hey Al,
The internal Drive is a standard 3.5 inch IDE 7200RPM unit. you can indeed upgrade this to a 1TB drive as long as it's IDE wether 2.5 or 3.5. Luckily when Lacie was originally offering these drives you could get these in 1TB, so that won't be an issue.
Ciza
Oct 28, 2008 | LaCie (300770) 250 GB Hard Drive
Satellite laptop hard drive crashed
you can have Toshiba MK1237GSX - 120 GB - internal - 2.5 inch - SATA-100 - 5400 rpm - buffer: 8 MB
this hard drive will work with your consisting config.
find it here :
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,MK1237GSX.aspx
Dec 28, 2007 | Toshiba Satellite A75-S211 Notebook
Computers & Internet Logo
239 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
